Go to Post Winning just makes your ego smile. - MooreteP [more]
Unread 01-02-2012, 20:13
ssirovica's Avatar
ssirovica ssirovica is offline
Programming Captain
AKA: Sasha Sirovica
FRC #1458 (Red Ties)
ssirovica is an unknown quantity at this point
Encoder Feedback From Jaguar
Our team has decided to plug an encoder into one of our Jaguars to regulate the speed of our shooter for more accurate results.
However, we are not getting any output from the encoder.
There is potentially a hardware or software issue.
Our Code:
Initialization
PHP Code:
try {
rightMotor1 = new CANJaguar(11CANJaguar.ControlMode.kPercentVbus);
rightMotor2 = new CANJaguar(12CANJaguar.ControlMode.kPercentVbus); //Change these to id Nums of jaguar!!!!!
leftMotor1 = new CANJaguar(13CANJaguar.ControlMode.kPercentVbus);
leftMotor2 = new CANJaguar(15CANJaguar.ControlMode.kPercentVbus);
rightMotor2.enableControl();
        } catch (
CANTimeoutException ex) {
ex.printStackTrace();
and here is our output code
PHP Code:
try {
driverStation.println(DriverStationLCD.Line.kUser31"Right Encoder Jaguar: " Double.toString(rightMotor2.getSpeed()));
          } catch (
Hardware wise everything seems to be wired normally except the Index signal which is supposed to go into the Jaguar is left floating because our encoder does not output an Index signal.
Any ideas?
Computers run on smoke. When you let the smoke out the computer stops working.
Unread 02-02-2012, 11:27
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Encoder Feedback From Jaguar
driverStation.updateLCD() needs to be called when you want the text to show up. (Every single time println is called)
Unread 07-02-2012, 02:10
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Any ideas?
It's most likely a software issue.
You have to tell the Jaguar the reference for the encoder.
I haven't tried it, but you should be able to set it without going into speed control.
(I have only tried it in position control mode, but after the reference is set, it works until the Jag is power cycled. That includes changing modes.)
What you should try is code that is something like this:
try {
   rightMotor1 = new CANJaguar(11, CANJaguar.ControlMode.kSpeed); // on the one that has the encoder plugged into it.
   rightMotor1.configEncoderCodesPerRev(360); // change to however many counts per rev on your shooter
   rightMotor1.enableControl(); // Not sure if this line is needed
   rightMotor1.changeControlMode(CANJaguar.ControlMode.kPercentVbus); //Change back to voltage mode now that the encoder is configured
   rightMotor1.enableControl(); // From this point on, you should see a speed on your debugging statements
   rightMotor2 = new CANJaguar(12, CANJaguar.ControlMode.kPercentVbus);
   leftMotor1 = new CANJaguar(13, CANJaguar.ControlMode.kPercentVbus);
   leftMotor2 = new CANJaguar(15, CANJaguar.ControlMode.kPercentVbus);
        } catch (CANTimeoutException ex) {
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 07-02-2012, 07:45
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Agreed, you are missing the encoder configuration.
