Go to Post You move on because FIRST isn't about the penalty or the un-penalty or whose robot is agressive and who is timid. - Collin Fultz [more]
Unread 31-01-2012, 21:08
cooltext cooltext is offline
FRC #0835
cooltext is an unknown quantity at this point
Crio doesn't find Camera images
Hello,
So I set up the camera with the camera setup utility, to connect through the router. (10.xx.yy.11). The problem is that I can see the image on the dashboard, but my code doesn't find the image. I know this sounds kind of weird, but when I used "camera.getImage();" it doesn't return an image and I get a null pointer exception error. Any Ideas?
Unread 01-02-2012, 19:25
severhale severhale is offline
FRC #4097
severhale is an unknown quantity at this point
Re: Crio doesn't find Camera images
I've got the exact same problem, anyone know what's going on?
Unread 01-02-2012, 21:35
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
Originally Posted by cooltext View Post
Hello,
Did you call getInstance() first? (I imagine so, since it appears on the dashboard, but, just in case...)
Unread 02-02-2012, 07:00
FRC #0835
thanks for your reply, but I found the problem. First make sure your camera is set to "10.te.am.11", than make sure it is plugged into the d-ling bridge. Then in the code, make sure instead of the plain .getInstance(); use the .getInstance("10.te.am.11"); so the crio can communicate with the camera. Also set the Camera up with the updated setup utility.
Unread 02-02-2012, 09:08
FRC #4097
Thanks so much cooltext! I'll try this out as soon as i can. too bad we already reset the camera and now have to reconfigure it...
Unread 12-02-2012, 22:41
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
We've been through all of these steps as well. We can access the camera, but the image return from GetImage() has 0 width and 0 size.
Suggestions?
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
