Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Unread 01-31-2012, 02:01 PM
astroman31 astroman31 is offline
FTC #4606
astroman31 is a jewel in the roughastroman31 is a jewel in the roughastroman31 is a jewel in the rough
Windriver can't setup remote system - license error
This Windriver stuff is getting old. This is my third attempt at getting the thing going. I have it installed on a fresh Windows 7 image on a very nice, very fast laptop. Installed both DVDs precisely as instructed. I can FTP the cRIO. I have the IP addresses set. Everything pings. Firewall turned off.
I cannot setup the Remote System connection in Windriver. It gives me licensing errors. Any ideas? The latest error says:
Problems Connecting Target
Step finished with this error: CPU: MPC83xx is not licensed
Target Context: VxWorks6x_10.40.86.2@WINDOWS-CNR8H59
Target Connect Strategy: Wind River VxWorks Target Connect Strategy
Connect Step: Connect DFW
Target Communication Protocol: TCP/IP
Target IP Address: 10.40.86.2
Target Port: 0x4321
Unread 01-31-2012, 10:00 PM
Re: Windriver can't setup remote system - license error
Searching the Chief Delphi forums for "MPC83xx" quickly found this thread. It's short, and it should help you find the step you missed when setting up the connection.
Unread 01-31-2012, 10:11 PM
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
you have to specify the processor as 5200 instead of "default from target".
Unread 02-01-2012, 10:55 PM
jnettleton jnettleton is offline
FRC #2501
jnettleton is an unknown quantity at this point
We changed the CPU type to MPC5200 for the cRIO (probably the same for cRIO-II 4 slot version).
