Go to Post You wrote a PID control loop for your coach? Whoa. - meatmanek [more]
Unread 01-02-2012, 22:45
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
pic: Gasp!
Unread 01-02-2012, 22:46
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: pic: Gasp!
I thought the Vex 393, along with the motor controller included, would be simply plugged straight into the Digital Sidecar? Would there be an advantage to dedicating a Jag to the 393?
Academic Student (Forever)
Unread 01-02-2012, 22:51
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: pic: Gasp!
I'm debating whether your "gasping" about the jaguar used for the motor, or that zip ties are connecting them to the electrical board? Is zip ties legal to use as the connectors for the controller??
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 01-02-2012, 22:56
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: pic: Gasp!
Zip ties are what make the FIRST world go round…
Normally, for a competition bot, we use 6-32 screws to mount our electronics, but right now on our proto-bot, hundreds of dollars of equipment are mounted with zip ties. It actually saved us once this year: We hit the barrier a little too hard, and the particle board we had everything mounted on broke right under the PD board. If that had been bolted down, it would have most likely cracked the mounting holes on it.
I'm right 90% of the time, so why worry about the other 3%?
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: pic: Gasp!
I can't seem to find anything in the rules about it, but I know your allowed to use zip ties on your robot.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 01-02-2012, 23:04
CalTran's Avatar
Missouri S&T Senior
Re: pic: Gasp!
Our team generally uses 8-32s for our board, but for prototyping we just grab a handful of 1.25" woodscrews, discover they have points on them (ouch), and then use them to secure to wood. I don't think there's anything against the use of zip ties for electronics, but you will have to deal with heavy suggestions to switch to screws or bolts.
Unread 01-02-2012, 23:14
Re: pic: Gasp!
Well i know you can use them on your robot... trust me we have containers full of them
just wasnt sure if you could mount stuff that way.
2013-Present
2010-2013
Unread 01-02-2012, 23:50
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: pic: Gasp!
Last year we used zip ties to mount out jagwires to our electronics board on the competition robot. Worked great, we never had any problems with anything coming loose. The only reason why we aren't doing it this year is that we are moving from mounting in an inverted "V" formation to a sheet metal tower.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 02-02-2012, 00:02
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: pic: Gasp!
I've been using zip ties for Jaguar and Spike mounting for years. They work just fine, even under significant impacts. They're light and nonconductive, and they don't vibrate loose. Since the Jaguars weigh 6 oz, and my tub o' zip ties indicates the tensile strength of the medium ones (which I use for this) is 75 lbs, I see no problem. For something like the PDB or cRIO, which has a bit more mass, I'd generally recommend stronger fasteners.
Back on the topic of the picture I'm not sure what benefit you'd gain using a PWM-controlled Jaguar with a Vex motor.
Unread 02-02-2012, 01:44
Aren Siekmeier's Avatar
on walkabout
Re: pic: Gasp!
This works? I know for a fact that VEX motors have built in speed controllers that operate off the same signal that the digital sidecar (with a jumper for power). I suppose this would still work just fine since you are giving it a 100% duty cycle signal and just varying the supplied voltage, in effect bypassing the built in speed controller. But what's the point?
Unread 02-02-2012, 02:09
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: pic: Gasp!
This is incorrect.
The old 3-Wire VEX motors had an integrated motor controller and were controlled directly by "servo PWM" pulse and could not be controlled via a Victor or Jaguar speed controller.
The new 2-Wire VEX motors (both the smaller 269 and larger 393 motors, the latter of which were included in the 2012 KOP) are just simple DC motor gearboxes. The are controlled on VEX robots by either directly plugging these into the 2-wire motor ports on the VEX Cortex controller, or by using the Motor Controller 29 (which functions just like a miniature Victor) plugged into a PWM port.
Art Dutra IV
世上无难事,只怕有心人.
Unread 02-02-2012, 05:56
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: pic: Gasp!
My only question would be is there a risk of damaging the motor running it at 12V+? The VEX system normally runs them off of a 7.2V battery.
Unread 02-02-2012, 14:43
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
FRC #1625 (Winnovation)
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
Re: pic: Gasp!
The Digital Sidecar with a power jumper is suppose to supply the correct voltage (7.2, I believe, but don't quote me ) for the 393, I'm afraid you might damage the motor running it at 12.
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
Unread 02-02-2012, 14:59
on walkabout
Re: pic: Gasp!
Originally Posted by artdutra04 View Post
This is incorrect.
I see. The one we tested must have been an old one we had lying around from a VEX kit somewhere (it worked straight off the sidecar). Good to know these are different.
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: pic: Gasp!
We are doing the same thing. The 393 data sheet calls it a 7.2V motor with 8.5V max so you are correct to be worried about applying 12V. Assuming you use CAN bus, the Jaguar allows you to set a VMax for lower voltage motors. I dont think i would try this using only PWM input to the Jaguar.
