Go to Post "If all else fails, use a bigger hammer" - Steve Florence - Logan Byers [more]
Unread 23-01-2012, 22:06
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Too many PWM's shorting out power?
First of all, this could apply to programming, motors, or electrical. I'm a programmer, so i'm going to post this here. If it needs to move somewhere else, someone in authority please do so.
I am programming in this year's LabVIEW.
Okay. We have been putting together a test robot to propel the basketballs into the hoops. We have 4 Jag's running (Drive) and 1 Victor running (Shooter).
All of the Jag's are put into the Digital Sidecar PWM slots 1, 2, 3, and 4.
The Victor is put into PWM slot 5.
When i disable the Victor, and run our Drive code, it runs just fine. No problems, no tinks, nothing. But, when we enable the Victor, and disable the drive code, nothing happens. Absolutely nothing. Could this be something wrong with the sidecar or something wrong with the Victor? All of the code is fine, all of the RefNum's are exactly the same.
Thanks, for any help.
Team Fusion 364
Unread 23-01-2012, 22:19
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Too many PWM's shorting out power?
if you plug the victor in to the PWM where a Jag was, does it enable with the drive code?
What do your LEDs do?
Is the victor response the same with and without a motor connected?
if the victor is not in the system, and you enable the drive and shooter code, does the drive still work?
Are your loops looping?
Unread 24-01-2012, 01:08
When you say "disable the Victor", what do you mean?
Since you're asking about programming, it would help greatly if we could see your code. Show us at least the relevant sections of Begin and Teleop.
Unread 24-01-2012, 01:42
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Is your digital sidecar powered by wires coming from the PD board? ie, are the BAT, 5V, and 6V LEDs on? I've heard that could make one or two PWMs work but not all of them. That doesn't theoretically make much sense, since the sidecar circuitry is mostly pass through for PWM, but hey.
Unread 24-01-2012, 03:18
Actually, the PWM signals are buffered on the DSC. It does make sense
Unread 24-01-2012, 13:55
Landonh12's Avatar
270 points
AKA: Landon Haugh
Disabling the Victor in the code.
I will post a picture later today, around 5 CST.
@WizendEE
Yes, the 5v and 6v lights are on.
Unread 24-01-2012, 15:28
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Troubleshooting information and Ideas:
Do you have your Victor PWM cable plugged in the correct direction?
Does enabling both do anything different?
Does plugging a Jaguar into the victor's cable work? Does plugging the victor into a Jaguars cable work?
Does changing the PWM port to say, 8 make it work?
What the problem sounds like is a hardware problem and not a software problem.
Unread 25-01-2012, 00:05
If the BATT LED isn't also on, that supports the idea that you might not be getting power to the Digital Sidecar properly.
Unread 25-01-2012, 00:11
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The reason it works is because the DS leeches power from the cRIO, which is generally enough to run a few of the outputs, but not all.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 26-01-2012, 11:16
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
A side note: Remember that you must configure your code to use either a Jaguar or a Victor (for each motor instance). Jaguar uses the full range of the Servo PWM signal coming out of the cRIO. If your code is configured for a Victor but you really have a Jaguar hooked up, the Jaguar will not swing to full forward or full reverse.
Unread 26-01-2012, 18:57
Landonh12's Avatar
270 points
AKA: Landon Haugh
The problem is resolved.
Most of the problem was wiring, and some was programming.
We had the code using a Victor, which is what we were using. Thanks.
Unread 26-01-2012, 20:26
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Could you specify the solution you found? We have a Crio that will only do 2 motors controlled at the same time and are utterly stumped.
Unread 28-01-2012, 12:12
Landonh12's Avatar
270 points
AKA: Landon Haugh
Our cRIO was plugged into the power supply for a camera, so it wasn't getting enough power.
What are you programming in?
Unread 01-02-2012, 21:45
el_pablo el_pablo is offline
AKA: Nicolas Bourré
FRC #4007
el_pablo is an unknown quantity at this point
We are having the same problem.
When we try to control more than 2 motors with the PWMs, the system starts to have problem.
Scenario 1
With the Axis camera, when running the 2 step motor, one of them starts to skip. Adding a third motor, both of step motors jitters.
Scenario 2
Using 2 jags and 1 victor, one jag skips every few seconds.
So what could be the problem? Power?
Thanks for helping
Unread 02-02-2012, 00:25
Originally Posted by el_pablo View Post
We are having the same problem...
The same symptoms suggest the same fix: make sure you are properly supplying 12 volts to the Digital Sidecar from a 20 amp breaker on the Power Distribution Board.
