Go to Post As a real pig farmer*, I definitely endorse team 1902. - Andy Baker [more]
  #121   Spotlight this post!
Unread 02-02-2012, 00:28
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
Re: 179 Swamp Teasers
Originally Posted by SuperNerd256 View Post
And that's my point! Maybe we'll start to see more successful robots that don't cross over the halfway point at all!
I'm glad to know that I have a "you-don't-need-to-cross-halfcourt" buddy.
179, I absolutely adore this robot. Depending on its scoring prowess, I can see this being a real dominating force at your regionals, but I'm sure that you'll be a great alliance partner no matter what happens. Thanks for sharing your great idea and good luck during the rest of build season!
  #122   Spotlight this post!
Unread 02-02-2012, 00:30
FenixPheonix FenixPheonix is offline
FRC #0751 (Barn2Robotics)
Team Role: CAD
FenixPheonix is on a distinguished road
They should be able to lower the bridge, I think. They can use the whole ramp as a lever arm to push it down and drive on top of it. It's clearly strong, since they lift their robot with it. Should be able to handle it, I'd guess.
  #123   Spotlight this post!
Unread 02-02-2012, 15:51
Mr B's Avatar
Mr B Mr B is offline
AKA: Andy Bradley
FRC #0233 (The Pink Team)
Mr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to all
Wow! Once again you have shown that you are one of the most creative teams in the world. Your concept has completely shifted the paradigm of a difficult three-robot balance. I look forward to seeing you in action in Orlando - expect many suitors.
  #124   Spotlight this post!
Unread 02-02-2012, 16:44
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Thank you Andy, Glenn, Roger, Eric, Gary, Mike, Brandon, Sean, Jared, Drew and everyone for all the compliments and interest, we appreciate it. I think the rules vetting is very informative as to how it will be perceived by the refs etc.
To try and answer a few of the questions:
  • When hanging it doesn't touch the lexan ball guard
  • There will be rubber strips under the top channel plate
  • The tip of the ramp retracts 3.5 inches to keep under the 14" perimiter when the ramp is horizontal then pops out when down.
  • Hadn't thought about the perimiter violation rule but I heard a Q&A allows it on the coopertition ramp without penalty
Another neat feature is the strain guages under the upper channel plate will measure upward force of the bridge so we can determine when opposing bot(s) weight is equal to our bots weight. Very colorful programmable LED strips will run up the sides of the ramp that can be seen from both sides of the ramp. The lights will rise as the weight rises, when they reach the top (equalized) they will blink red indicating whoever is driving out to the other end of the bridge to stop moving, then we lift. Plus we will use them like runway lights while the ramp is ready to be climbed. This bot should come in around 110lbs with bumpers, it's very light. I can't wait to see all this stuff do what it supposedly does.
www.179swampthing.org
  #125   Spotlight this post!
Unread 02-02-2012, 17:12
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Nice idea. From my experience with strain gauges, I recommend you use a couple of them in different spots along the contact area and average the values. Then you can compare to one single gauge if you so choose. Last thing you want is momentum or non-equilibrium giving false readings.
But you've thought of all this already, haven't you?
Cold Fusion's 10th Season
  #126   Spotlight this post!
Unread 03-02-2012, 19:33
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Originally Posted by Cory View Post
Nothing is guaranteed. The average regional match would probably feature teams that have trouble climbing the ramp.
Not to take anything away from 179, but everyone on Chief always freaks out and starts exclaiming "EINSTEIN!!!!" as soon as they see the first out of the box/good robot posted. It's never that simple.
It'll happen again when we get our first great looking robot reveal video (usually reserved for 118). Ever notice you never see one from 1114, 71 or 67 (Wildstang did it in 2004)?
  #127   Spotlight this post!
Unread 03-02-2012, 19:36
Andrew Lawrence
Posts: n/a
Yup! Best one to date, IMO. http://www.youtube.com/watch?v=5MgdG...&lf=plpp_video
  #128   Spotlight this post!
Unread 03-02-2012, 21:23
pfreivald's Avatar
AKA: Patrick Freivald
Neat robot! Very aggressive in terms of rules interpretation -- I don't think I'm that brave... I'm not sure if that's a caution or a compliment!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #129   Spotlight this post!
Unread 03-02-2012, 23:51
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
The Q&A actually said the opposite:
Q:If a robot is designed to be contacted inside its own frame perimeter to aid in balancing, could a team request a waiver of G27 for touching inside its own frame perimeter to aid in balancing the coopertition bridge with an opponent?
A: No.
So any opponent robot that tries to climb you will earn themselves a G27 violation, complete with technical foul. Of course, you may well find times where this an entirely worthwhile tradeoff. Being qualifications though, I wish your coach luck in negotiating these and determining in-match whether they'll actually happen, if you decide to go that route.
Note that G27 can also earn the opposing robot a yellow card for repeated or egregious violations. You may want a Q&A, but I'd suspect there's nothing much repeated (at least not in a single match, and I doubt you'll coopertition balance with the same robot twice) and certainly not egregious.
  #130   Spotlight this post!
Unread 04-02-2012, 17:10
Swampdude's Avatar
AKA: Dan Quiggle
Video: It's alive!
  #131   Spotlight this post!
Unread 04-02-2012, 18:22
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Very Very nice. I'm liking the wheelies that you're doing, it's a new method of getting over the barrier!
  #132   Spotlight this post!
Unread 04-02-2012, 20:47
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Never?
http://vimeo.com/3277978
  #133   Spotlight this post!
Unread 04-02-2012, 21:41
AKA: Simon Bohn
I always look forward for 148.
  #134   Spotlight this post!
Unread 07-02-2012, 06:44
caseydech caseydech is offline
None #1391
caseydech is an unknown quantity at this point
Three things
1: I love the idea of the arm, my team thought about and still might make one of those
2: A concern about a possible issue, when it is latched onto the ramp, the robot's ramp and its latcher ( not sure what to call it) might be both considered outside of the robots perimeter, maybe there would be a way to fix that
3: One of the reasons my team didn't build this right away was because we think there will be a rule update prohibiting this kind of latching on to something
Hopefully it will be allowed, because I love this idea and I'd love to see it in competition, major wowfactor
  #135   Spotlight this post!
Unread 07-02-2012, 08:43
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
I dont see the pictures of this robot everyone is talking about?
