Go to Post Using my Little Orphan Annie Secret Decoder Ring, I have determined that the game hint reads: "Be sure to drink your Ovaltine" - Jill_ls101 [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 02-02-2012, 01:31
Vadman Vadman is offline
AKA: Vadim
FRC #1351 (TKO)
Vadman is an unknown quantity at this point
Wind River Registry: Error launching Wind River Registry on localhost
Hello all,
I am new to using Wind River, but I have been having some problems installing it. First, I installed it on Windows 7 64Bit on my old computer. Everything was working fine. I was able to deploy code. However, when I tried to install on my new computer, I installed it exactly the same way. However, when I am trying to add the connection to the robot so that I could deploy code, Wind River gives me the following errors:
Error launching Wind River Registry on localhost.
'Launching and connecting to Wind River Debug Server (DFW) Backend...' has encountered a problem
When I open the Wind River Registry itself, it displays the following:
Wind River Registry initializing ... Error: Unable to register wtxregd with portmap service.
com.windriver.tm.core
org.eclipse.core.runtime.OperationCanceledExceptio n: Error launching Wind River Registry on localhost
Possible cause:
Timeout connecting to Wind River Registry after launching it. Please try "Refresh" on the Registry node later.
I have never seen this error before, and I could not find any solutions to it. Please help, because I need to be able to deploy code.
In addition, I have tried copying C:/WindRiver folder from my old computer to my new one. That created the propper connection, but as soon as I tried to connect to the robot, it gave me the same errors.
Any help is appreciated.
- Vadim (TKO 1351)
Unread 02-02-2012, 08:06
Re: Wind River Registry: Error launching Wind River Registry on localhost
Is there an antivirus program running that might be interfering with the WindRiver tools? I don't know how its Registry is implemented; might a Windows firewall be getting in the way?
Unread 02-02-2012, 10:42
AKA: Vadim
FRC #1351 (TKO)
I specifically disabled my antivirus and firewall. Still getting the same error. I installed all Wind River updates as well, so that is not the problem.
Unread 02-02-2012, 15:27
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Check the target definition or try deleting the target and redefining it making sure following the example in the "Getting Started" guide.
Brian K
Team 1225 Robotics Mentor
Unread 02-02-2012, 18:13
AKA: Vadim
FRC #1351 (TKO)
The problem is that when I right click to add a new connection, it does not display the "WindRiver VxWorks 6.x Target Server Connection."
Unread 02-02-2012, 20:58
After you installed it, did you also run the C++ update?
Unread 09-02-2012, 00:25
AKA: Vadim
FRC #1351 (TKO)
Yes, a new update came out on 02/04/2012, and I installed that as well. I have an older laptop on which I also installed Wind River. Both are 64bit. On that older laptop, Wind River works perfectly For now, I guess I will have to continue using that laptop. If anyone knows a solution, please reply.
Unread 17-05-2012, 21:24
pathwalker pathwalker is offline
pathwalker is an unknown quantity at this point
Hi Vadman,
I did experience what you encountered. On my notebook, I have Tornado Registry earlier as I am still using VxWorks version 5 for development. Lately I installed version 6, and the same problem came to me as what you experienced. I later shutdown my Tornado Registry and the Wind River Register started to work.
I am not sure if this will help. Good luck!
Unread 18-05-2012, 19:31
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
IIRC, the FIRST downloader plugin connects independently. You should still be able to deploy code without a connection in workbench.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
