Go to Post The fact that although many of us disagree on specifics of how FIRST should conduct events, design a game, and facilitate as much fairness between teams as possible, in the end we still greatly enjoy each other's passion for FIRST and provide genuine respect for each other - Andy Baker [more]
Unread 02-02-2012, 05:52
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
Attaching Thermostats
Do you suppose (assuming I could power them legally) that it would be legal to attach 2 old style mercury thermostats to our robot. Any rules that would prevent this?
Unread 02-02-2012, 06:21
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Attaching Thermostats
Mercury is a hazardous material, and likely would not be allowed on the robot.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 02-02-2012, 06:24
wilhitern1's Avatar
AKA: Neal Wilhite
But is there a rule?
Unread 02-02-2012, 06:32
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
[R08] ..
This message is hidden because Jack Jones is on your ignore list.
Unread 02-02-2012, 06:38
wilhitern1's Avatar
AKA: Neal Wilhite
There really is only a tiny amount of mercury in them. About the same as a normal thermometer. Also, did you know that there is mercury in every flu shot... How about circuit boards. There's mercury in some of them. There are also radio active isotopes in many modern circuits. I guess I want to know how much is too much if there is a rule.
Unread 02-02-2012, 06:42
wilhitern1's Avatar
AKA: Neal Wilhite
Originally Posted by Jack Jones View Post
[R08] ..
Personally, I would say that it is not intended to apply to this. I suppose that I'll have to ask Q&A.
Unread 02-02-2012, 06:46
Hodge1
Ask the GDC if you want an official ruling. Look up R08, and by the way, there is a lot more mercury in the thermostat than a thermometer.
Sweat the details
Unread 02-02-2012, 07:24
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
The other question to this is what are you trying to acomplish by attaching them? Some members of the CD community may be able to help you come up with a better solution. Give us more detail about what you want to do with them and let us see if that is the only solution. My guess is that the GDC will tell you no, but I have been wrong before.
Unread 02-02-2012, 07:36
Gdeaver Gdeaver is offline
FRC #1640
Sounds like a tilt sensor. Not only is mercury a haz mat but, it would slosh around and not work well. A highly filtered accelerometer would work as a tilt sensor.
Unread 02-02-2012, 08:13
Wil,
Mercury is not allowed under the referenced rule. Among other things, it is impossible to get out of the playing field carpet. As Gary has pointed out, there are several alternatives for what your intended use might be.
Unread 02-02-2012, 10:31
wilhitern1's Avatar
AKA: Neal Wilhite
Originally Posted by Gdeaver View Post
...A highly filtered accelerometer would work as a tilt sensor.
On another channel, a "digital gyro from this year's kit of parts" was suggested. Is that also equivalent? And how hard will it be to make work?
Unread 02-02-2012, 10:33
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Why not use a ball bearing in a tube instead?
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 02-02-2012, 12:59
The kind of gyro supplied as an FRC kit part will not work well as a tilt sensor. You definitely want an accelerometer.
Unread 02-02-2012, 14:07
wilhitern1's Avatar
AKA: Neal Wilhite
You don't happen to know what it reports do you?
Unread 02-02-2012, 14:17
wilhitern1's Avatar
AKA: Neal Wilhite
What if you mounted it on it's side?
