Go to Post We asked the neighbors if we could block the road before we did it. We had the rack out for a couple of hours. They are getting used to us doing odd things during build season. - wendymom [more]
View Poll Results: "Shooter" or "Dumper"?
Shooter 145 87.88%
Dumper 20 12.12%
Voters: 165. You may not vote on this poll
Unread 01-02-2012, 00:54
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Shooter or Dumper?
Our team is going with a shooter. It is much more risky than a dumper, but with a practice robot and some excellent programmers, I hope we can pull it off. I would recommend that any team that has yet to decide should concentrate on having a consistent dumper rather than a shooter that might never work.
Unread 01-02-2012, 07:26
nssheepster's Avatar
nssheepster nssheepster is offline
Da' Rule Man
AKA: Nik Shepherd
FRC #0174 (Arctic Warriors)
nssheepster is an unknown quantity at this point
Can you really do that? I didn't think you could touch the fender. I thought it was a foul.
In theory, this should work.
In practice, not so much.
F.I.R.S.T. = For Inspiration and Recognition of Science and Technology
So really, it's F.I.A.R.O.S.A.T.?
Nah, that doesn't sound as good.
Unread 01-02-2012, 07:59
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
Not sure which message you are commenting on. But the rule [G10] is that you can't sit on or push off of (or "react against") the top of the fender.
You can touch the sides of the fender.
Unread 01-02-2012, 12:45
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
CHeck the rules. Find one that concerns you. And ask back here.
As I have been learning lately, if someone can't quote you a rule number, ignore the heck out of them. If they can, don't believe them till you look it up.
Unread 01-02-2012, 12:52
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Voting is dangerous. Votes mean an option is chosen because it is popular, not because it is right. Votes are intrinsically subjective. Votes generate divisiveness and hard feelings. This is an engineering challenge. If one system can be shown to be superior to the other, given your team's constraints, then it is the better system for your team.
There will be excellent shooters. There will be excellent dumpers. There will be dozens of opportunities for "I told you so"s. It's up to your team to not fall into that trap - whatever you decide as a team, is the team's decision. Believe it or not, these moments are pivotal in a team's identity and cohesiveness. Attack the problem as a united front, and reap the success on the playing field.
Hi!
Unread 01-02-2012, 15:01
wilhitern1's Avatar
AKA: Neal Wilhite
Originally Posted by Taylor View Post
Voting is dangerous. Votes mean an option is chosen because it is popular, not because it is right. ... This is an engineering challenge. If one system can be shown to be superior to the other, given your team's constraints, then it is the better system for your team...
And who gets to decide this. Do we arm wrestle for it? Do the mentors decide? No mater what method you choose your objections in voting also apply...
Unread 01-02-2012, 15:08
Taylor's Avatar
AKA: @taylorstem
There are lots of ways - decision making matrix, weighted values table, list pros v cons - there are a litany of ways to make a scientific decision based on process rather than emotion.
Hi!
Unread 01-02-2012, 15:10
Not really. Ever hear of a weighted objective matrix? If you haven't, I'll explain below.
Voting should only be used if two designs come out the same or extremely close to the same on a weighted objective matrix.
The way this sort of matrix works is the you have a number of requirements or goals, each with a weighting of how important it is. For example, rules compliance would get a 5 on a scale of 1-5, while "cool" gets maybe a 1 (if it's even considered). Each design is evaluated against the same set of requirements and given a score (on a scale of 1-5 or 1-10) on how well it meets that requirement. High score wins. Very close high scores get sent to a more detailed matrix for further evaluation, and the process repeats.
Unread 02-02-2012, 07:29
Da' Rule Man
AKA: Nik Shepherd
We used a weighted decision matrix. But I am staring, currently, at 104 votes, 94 of which are for shooters. So they seem to be the really popular choice.
Unread 02-02-2012, 08:09
Taylor's Avatar
AKA: @taylorstem
Very few of the voters are on your team. Just because shooters are popular with the CD community, which tends to skew toward the more proficient, does not mean that's the best choice for your team this year.
Mecanum wheels tend to be rather popular among the larger FRC community, but I don't expect to see any on 2791's machine any time soon.
Hi!
Unread 02-02-2012, 09:31
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
One important thing that Mr.Bill taught me was that every team needs one person with the authority to make the final decision when there is a dispute to avoid long delay's.
His two rules are:
Putaside - if your design or idea isn't you need to put it aside and move on.
Golden Rule - It's his gold so he rules!
Unread 02-02-2012, 09:40
JohnFogarty's Avatar
AKA: @doctorfogarty
We tested them on our off season.
They won't be on our robot any time soon either.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
Unread 02-02-2012, 09:41
Andrew Lawrence
Posts: n/a
Exactly. Another thing to consider is WHO is voting. The "wow factor" of a turreted shooter seems cooler, but how accurately will most teams be when shooting, especially farther away from the baskets? I'm not saying people won't be aiming well, but which is more accurate: A shooter from the key, or a dumper right in front of the basket?
Unread 02-02-2012, 09:43
pfreivald's Avatar
AKA: Patrick Freivald
Let's not turn this into yet another mecanum thread. The point is taken -- people have different opinions on solutions, and some of those people are likely more right than others... and some of those answers will be different for different teams, based on many, many factors.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 02-02-2012, 09:50
AKA: @doctorfogarty
The thread seems to have veered into more team politics than actual advantages or disadvantages of shooters/dumpers.
John Fogarty
