Go to Post Deodorant cannot be stressed enough. To quote a teammate "body odor is a body don't-or." - C. De Vries [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 01-02-2012, 21:33
Neko81795 Neko81795 is offline
FRC #1318
Neko81795 is an unknown quantity at this point
Math for Finding the distance to the hoop
This is a XML slideshow showing how to find the distance from the turret to the hoop using the distance and angles from the camera to the backboard. if there are errors in my math, please correct me.
file is up to date as of 2/2/12 3:23 PM
Unread 02-02-2012, 10:07
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Math for Finding the distance to the hoop
I have a question...I can see how you could get the Kinect camera to find the distance to the backboard. However, how did you get theta (the angle of the camera to the backboard)?
Unread 02-02-2012, 10:24
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I would also think about fixing the camera at a set angle, you get a good range of visibility. Then you can find distance based on where on the screen the target is.
Unread 02-02-2012, 10:28
Mostly typos:
Page 10 first equation has the denominators swapped
Page 16 what's the area calculation for? you can get H directly from sin(90-(theta+s))=H/Q
Page 19 should be sin(90-(theta+s))
Here's another way to do it:
I = 180-o
T = sqrt[R^2 + C^2 - 2*R*C*cos(I)]     (Law of Cosines)
s = asin((R/T)*sin(I))     (Law of Sines)
w = 90-(theta+s)   <-angle between T and Q
H = Q*sin(w)
B = Q*cos(w)
F = sqrt[H^2 + (T-B)^2]
Unread 02-02-2012, 18:18
FRC #1318
Sorry about those typo's. Here are the changes. also, my calculations were in deg. i changed them to rad which is what the coding usualy uses. Ether is right about using the law of cosines, I just went over it today and couldn't remember it before. that was my fault.
we are not using the kinect. we are using the axis camera and ratios to find the distance and angles. however, I wasn't working on getting the images, i just did the math so I can't help you there.
