Go to Post I believe you have the right to develope your own opinion. I would suggest it be based on actual experience and facts. - Mike Copioli [more]
Unread 01-02-2012, 16:25
Gatekeeper Gatekeeper is offline
FRC #4054
Gatekeeper is an unknown quantity at this point
Ultrasonic Coding
Our team is trying to set up the MaxSonar Ultrasonic Range Finder but we are having a problem with the Java code for it. We are trying AnalogChannel but we are not sure what values will help us calculate the distance for the ultrasonic.
Could someone give us an idea if AnalogChannel is the right function to be using or if we need to use another function?
If it is possible at all too does anyone have an example of what we can use to calculate distance with the MaxSonar?
Unread 02-02-2012, 11:38
loafdog loafdog is offline
AKA: Maciej
FRC #2876 (DevilBotz)
loafdog is an unknown quantity at this point
Re: Ultrasonic Coding
Try searching the forums... I found:
http://www.chiefdelphi.com/forums/sh...d.php?t=101309
and:
http://www.chiefdelphi.com/forums/sh...light=maxbotix
and this thread, post #5 especially..
-Maciej
