Go to Post Strive for excellence in everything you do, but also recognize it in others when you see it, rather than try to drag it down. - Joe G. [more]
Unread 16-01-2012, 04:28
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Securing Machine Keys
Hi, would it be safe to secure a machine key using Gaffer's tape and cable ties? What methods would you recommend for a team with limited machining capabilities?
Unread 16-01-2012, 08:47
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Securing Machine Keys
A set-screw isn't a bad way to go, I've drilled and tapped set-screws with a cordless drill and hand tap. I like the set-screws with knurled or pointed tips and a little bit of blue Loctite to keep them from backing off.
Recently I've come to the conclusion that as along as the key can't slide out along the keyway it will be fine for FRC purposes. Close-fitting axle spacers work well, and this year we've tried peening the keyway closed at the end, so far so good.
Unread 02-02-2012, 00:51
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
At a competition, the key kept sliding out from our drive gearbox. The solution: Krazy Glue.
I'm a mentor looking for a home in Southern California! I know Java, C++, electrical and mechanical.
Need Java or C++ help? Send me a PM!
Unread 02-02-2012, 05:40
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Depending on the situation and motor:
For cims we use these:
McMaster: 94800A730
For other various applications we avoid keys for multiple reasons:
-You lose them easily
-A pain to put in and take out
-Would rather use HEX shafting.
If you are left with a key:
-Use PushNuts (Linked Above)
-Clamp Collars work great if you have clearance.
-Snap rings work great (Need a lathe of some sort)
-RC
R.C.
MadTown Robotics Team 1323
Unread 02-02-2012, 08:19
Munaum,
Sorry, gaffers tape is not considered a fastener. You would be unhappy with the results. The set screw is the best solution for you.
Unread 02-02-2012, 08:36
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
McMaster: 94800A730
-RC
Would these solutions work just as well for steel hex shafts? If not, is there a good retainer for steel hex shafts?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 02-02-2012, 09:14
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
I have at times cross drilled a shaft starting right in the key-way. A cotter pin then can be used to secure both the gear and the key. But of course this assumes that you have clearance for the cotter pin, and are able to cross drill the shaft, which are sometimes hardened to the point where drilling is extremely difficult. In this case a small diameter carbide tipped concrete drill (one that has never been used even once on concrete) can be effective in drilling some of the hardest materials. But always exercise extreme caution when working with such hard materials.
This is the zeroth day of the rest of your life.
Unread 02-02-2012, 09:32
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
If you need an 1/8" key, the VEX axles work great.
Hi!
Unread 02-02-2012, 09:52
pfreivald's Avatar
AKA: Patrick Freivald
You can put a small tack from a welder on either side of the key in certain applications (but cover the keyway to avoid spatter).
We have in times past mangled the keyway with a chisel on either side of the key, thus preventing the key from sliding loose. It never failed us, but there are generally better ways to do things.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 02-02-2012, 09:57
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
We just use a bit of crazy glue, and glue the key to the gear/wheel/vial of winsauce.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 02-02-2012, 10:39
pfreivald's Avatar
-Nick
I don't believe winsauce is COTS!
Team 1551
I write books, too!
Unread 02-02-2012, 12:41
Commander Canada
It's a custom component.
-Nick
Unread 02-02-2012, 13:22
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If you are referring on how to capture hex shafts so they don't move, my preferred method is to capture it by turning the ends on a lathe into round and using flanged bearings on either side. I've also used a combination of Delrin spacers with either shaft collars, E-clips, or tapped ends of the shaft (with fender washers) to retain it.
In the case of the shaft collars, I had the section of hex turned down to round and used an aluminum split shaft collar.
Art Dutra IV
世上无难事,只怕有心人.
