Go to Post It can't be too bad... it's Canada! :) - Brandon Martus [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 02-02-2012, 13:45
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Powering the 2CAN 2.0
Hi guys-
We got our new 2CAN 2.0 (after having a lot of problems using the serial to CAN last year) and I'm about to start hooking it up, however I have a quick, probably easy, question.
How do you supply power to it? I know it gets plugged into a 12V slot with a 20A breaker, but what connector do I use? It says it accepts a push-in type power connector that accepts up to 16 gauge wire, but what does that mean?
I'm assuming it is a bad idea to just shove some wire in there.
