Go to Post Life is so much better when you do what you love rather than what others want you to do. - KelliV [more]
Unread 02-02-2012, 08:55
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
Cypress Board not recognized by non-classmate
we can get our classmate to see the cypress board but not our pc, configured like a driver's station. we also purchased the estop custom control interface board
http://www.estoprobotics.com/estore/...d&productId=33.
it works beautifully, thanks estop and only cost 40.00.
but we believe we should be able to get our new cypress board working too.
we have purchased a new cypress board
CY8CKIT-003, although digikey was selling a CY8CKIT-003A. don't really know if there is a signficant difference.
we have tried uninstalling and reinstalling all cypress software, still cannot get our non-classmate pc to see the cypress board.
on the classmate, we can see the psoc board via the I/O tab but not on any other pc.
we have read the first forums post, simliar to this but i'm not sure it the folllowing post applies to us
http://forums.usfirst.org/showthread...highlight=psoc
any help here?
http://www.team1912.com
2013, 2012, 2011, 2010 Regional Chairman's Award, Bayou Regional
2013 Woodie Flower's Award, Bayou Regional
2012 Dean's List Winner (Rachel Holladay)
2015, 2014, 2013, 2012, 2011, 2010 Beta Test Labview/Hardware
2012, 2011 Best Website, Bayou Regional
2011, 2009, 2006 Gracious Professionalism
2007 Bayou Regional Winner
Unread 02-02-2012, 11:23
Re: Cypress Board not recognized by non-classmate
Did you check if the CyMiniProg3Service is running?
Check it (XP) under Start -> Services -> Control Panel -> Administrative Tools -> Services
Win 7 is similar but I don't have the menu path memorized.
Did you install the Cypress DVD by accident (or on purpose), or run any online updates onto your other laptop?
You can check the Cypress versions:
Cypress PC program – Start->Programs->Cypress->PSoC Programmer 3.12
  • Driver Station Install 3.12.0.827 (correct version)
  • Update from Online 3.12.4+ (user did an online update - incorrect)
  • Cypress DVD case 3.10.0.440 (user installed the Cypress DVD – incorrect)
I haven't verified that this year hasn't changed these versions though.
Unread 02-02-2012, 13:04
we did not use the dvd that came with the board and i think we did check for the service running under windows.
i know we are running the updated driver's station.
i will verify all these items tonight.
thank you for the helpful post.
Unread 02-02-2012, 14:12
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Did you reprogram the Cypress with the programmer and the hex file installed with the utilities update? Without this, it won't be recognized.
I'm right 90% of the time, so why worry about the other 3%?
Unread 02-02-2012, 15:52
we did
Unread 03-02-2012, 10:31
We got our cypress board working. The problem started we believe when we used the vendor supplied DVD as a starting point.
We ended up fixing the problem from an extremely helpful post on first forums, giving dll sizes. When we deleted the dll and replaced it with one from the classmate, using the file sizes as a guide, all worked.
We have made all the driver's station updates. We assume the vendor DVD put a bad dll out there.
thanks to all who helped.
i still like the board from estop robotics better, it works everytime, no issues.
Unread 03-02-2012, 13:56
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The files actually come with the driver station update.
Unread 03-02-2012, 14:11
Cecil's Avatar
AKA: Alex Hummel
My bad.. I knew it was one or the other..
Hence my signature
Unread 03-02-2012, 14:34
The "correct" version didn't change, but I feel certain the DVD version would have.
One tip that can help teams that have installed the Cypress driver update from the web is that this can be made to function properly by copying the Program Files\Cypress\Programmer\3.12\Service\ftk_3_simfw. hex from a properly installed Driver Station. This is the file that gets overwritten by the Cypress update. The Driver Station needs this particular version of the file to read data from the board. The size should be 29,663 bytes.
Be sure to refer to the new Cypress troubleshooting guide at the end of the "Getting Started with the 2012 FRC Control System" document on usfirst.org.
