Go to Post Advances in STEM are meant to benefit everyone, so even the most basic-level of understanding deserves to be validated and encouraged. - moamomen [more]
Unread 02-02-2012, 00:49
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Too many PWM's shorting out power?
Originally Posted by el_pablo View Post
Scenario 1
With the Axis camera, when running the 2 step motor, one of them starts to skip. Adding a third motor, both of step motors jitters.
To add to Alan's response, check to make sure that the frame of the Axis camera is isolated from the robot's, as the Axis camera is grounded to its frame.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 02-02-2012, 10:18
el_pablo el_pablo is offline
AKA: Nicolas Bourré
FRC #4007
el_pablo is an unknown quantity at this point
Here is a video I made yesterday during the testing.
It's in french but I wrote in a previous post what is happening.
Youtube video here
As you can see, it jitters even when not running.
Here is a screen shot of our begin.vi
Here is the teleop code
Thanks for helping
Unread 02-02-2012, 12:51
el_pablo:
When you said "step motor" before, did you mean "servo"?
You're defining the camX and camY servos, but you never command them to move.
The nouveauMotor device reference is not defined in Begin. You should be seeing an error message on the Driver Station telling you about that.
I can't see YouTube videos from where I am, but I'm going to guess that you haven't installed the servo power jumpers next to the PWM pins on the Digital Sidecar for the camera servos. If they are indeed being powered, then a "twitch" is usually an indication that they're not getting a PWM signal, and are just picking up noise on the wires.
Unread 02-02-2012, 13:59
AKA: Nicolas Bourré
FRC #4007
Sorry my mistake, they are servos not stepmotors.
The diagrams show the second scenario which includes 2 jags + 1 victor and no servo. Althought they are declared we don't use them in this test case.
Concerning the servos, the power jumpers are installed.
We started the project using the default template. Should I delete a few things before coding?
Thank you
Unread 02-02-2012, 14:16
AKA: Nicolas Bourré
FRC #4007
Just figured out that in the begin.vi there were some "junk" declaration out of the screen in which some PWMs were in conflict...
I hope this is source of the problem.
