Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 02-02-2012, 16:05
chall3613 chall3613 is offline
AKA: Candace
FRC #3613 (Team Wolf Pack)
chall3613 is an unknown quantity at this point
Re: Joystick Buttons to Control Jaguars
oh no...i just tried building the program and it said the vi was broken.
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1003 occurred at AB_Targetfile.lvclass:Open_Top_Level_VIs.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_RTEXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: The VI is not executable. Most likely the VI is broken or one of its subVIs cannot be located. Select File>>Open to open the VI and then verify that you are able to run it.
Unread 02-02-2012, 16:41
Open the vi and click the broken run arrow at the top of the window. You'll be able to see a list of the errors. Double-click an error and you'll be taken to the spot with the problem.
Unread 03-02-2012, 13:58
AKA: Candace
It says both the MotorControlRefNumSet and Get dont have the correct wireing.
"The designer of this subVI has specified that this terminal must be wired. Show the Context Help window to see what the required connections should be."
Unread 03-02-2012, 17:41
So do what it says. What required connections did you leave unwired?
Did you know that the picture I posted isn't just a screen capture? It's actual LabVIEW code. You can save the attachment as a .png file, then just drag the file into your Teleop vi using Windows.
Unread 04-02-2012, 10:16
AKA: Candace
Thank you very much I was just missing the refnum name. Thank you for all the help.
I really do apreciate it. Ill let you know how the test drive ends up.
Have a good day!
