Re: EP4 Encoder
I'm pretty sure the encoder is installed correctly. As for wiring the first wring plugging into the encoder is orange and plugged into a PWM cable for the Digital sidecar. The second wire is blue hooked up to the signal wire of the PWM cable. The third wire is brown and connected to the ground part of the PWM. The fourth wire is yellow and hooked up to a standalone wire connected to the signal port of another slot on the digital sidecar. The PWM is connected to slot 5. The standalone signal wire is slot 7. I have made sure the code matches up with the port numbers they are plugged into
