Go to Post What is this sleep you all speak of...if it wasn't in the KOP than it is not allowed to be used :D - Wayne Doenges [more]
Unread 02-02-2012, 16:10
Jerry Li Jerry Li is offline
FRC #4203
Jerry Li is an unknown quantity at this point
How to use sonar and detect retro reflective tape
Hello again! I was wondering how to use the MaxBotix sonar to detect distance and use the axis camera to detect the retro reflective tape. I have found 2 labview example codes that shows how to do that.
The sonar program is named:
EZ1 MB1010 Sonar - Analog.lvproj
The vision detection is named:
Rectangular Target Processing.lvproj
I don't know if those are the actual programs we should use or if there is another one. If those are the codes, then how do we put the project or code onto our begin and teleop.vi project? We don't know how to make it so that the sonar and vision code will run with the rest of our robot code. Any help is much appreciated.
Unread 02-02-2012, 16:42
Re: How to use sonar and detect retro reflective tape
The target processing has instructions inside it for adding it to your robot project.
One of the LabVIEW tutorials explains how to incorporate the simple examples into your robot project.
Unread 02-02-2012, 17:06
FRC #4203
Can you point us in the direction of the tutorial? Thanks for the response!
Unread 02-02-2012, 20:23
When you launch LabVIEW, the starting screen has a series of tabs on the left side. The second tab from the top is "Tutorials".
Unread 03-02-2012, 17:01
FRC #4203
Thanks
