Go to Post Possibly the most amazing thing all week was that this game can be played with mecanum wheels. - fargus111111111 [more]
Unread 02-02-2012, 17:04
Re: No clue where to start on Programming...
Originally Posted by Team3763 Adam View Post
However, we have NO lights on the Sidecar, and it IS the one provided this year.
No lights would be bad.
Do you have 12 volt power connected to the Digital Sidecar's power input from a 20 amp circuit on the Power Distribution Board? You should. There is enough leakage through the signals from the cRIO to power a couple of PWM outputs, but you're not supposed to rely on that accident.
To permanently load code to the cRIO, "Build" and then "Run as startup". There's really no use for the "Deploy" command in that popup menu.
