Go to Post A lot of people forget this when posting, but your posts here on ChiefDelphi will more or less be here forever. Do you really want that post you just be made to be on the Internet forever?... Post wisely... - artdutra04 [more]
Unread 02-02-2012, 18:26
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Using Command base system
so... I'm trying to use the new command base system, so I've gone through the cookbook thing. I don't understand how to make a button on a controller link to a command. The cookbook uses a button class that isn't in the library, so how does this work?
Unread 02-02-2012, 18:33
Re: Using Command base system
It sounds like you're looking for the classes in wpilibj.buttons
Unread 03-02-2012, 11:15
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Button js1_button1 = new JoystickButton(js1, 1); // Create a Joystick Button, arguments sent to the constructor are (stickObject, button number)
js1_button1.whileHeld(new CommandHere()); or js1_button1.whenPressed(new CommandHere()); // buttonObject.whileHeld, whenPressed, or whenReleased (new Command Name());
