Go to Post It is crucial to keep experience and keeping collected under pressure as high points that can't be measured in a test. - jnelly [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 02-02-2012, 19:23
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Alternate chassis lift kit
I'm part of team 4072 (A rookie team).The currently Andy Mark is out of stock of the chassis lift kit. Are there any other good solutions on where to get one?
Unread 02-02-2012, 19:34
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Alternate chassis lift kit
You can try bolting another C-channel extrusion under the frame, this will give you an extra inch, and with 8inch wheels is just about enough to get over the bump [which I assume is what you want to do].
EDIT: http://www.youtube.com/watch?v=xcI2L6HyDQc
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 02-02-2012, 19:52
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
How much lift are you looking to get?
A quick and easy way to get the KOP frame high enough to get over the bump is to bolt some lengths of 2x1x.125 Tubing to the bottom of the frame and run your axles through that. If you want bonus points you can miter the ends of the tube to a 45* or so to give you a little help in getting over the bump.
-Dustin Benedict
Unread 02-02-2012, 20:05
Andrew Tucker
AKA: Andrew Tucker
Take you for the info. However I am confused by what you mean when you say 2x1x.125 Tubing.
Unread 02-02-2012, 20:12
Jim Wilks Jim Wilks is online now
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Rectangular aluminum tubing 2" x 1" outside dimensions and 0.125" (or 1/8") wall thickness.
Unread 02-02-2012, 20:15
thefro526's Avatar
Mentor for Hire.
Check out this picture:
2x1x.125 Tubing refers to the size of a piece of Rectangular Aluminum tube. In this case, 2" would be the 'B' dimension, 1" would be the 'A' dimension and .125" would be the 'C' dimension.
If you were to take this piece of tubing in a short length, let's say 3"-6" long, and bolt it to the bottom of your chassis using the 2" dimension as your height, you could raise your axles up a total of ~1.5" to 2" depending on where you drill holes in the tube. If you were to make a 45* cut into the tube and make that 45* portion stick out in front of the leading edge of the wheel, it would contact the barrier first and start lifting the chassis up before the wheel hits. That would make it easier to get over the bump with KOP wheels.
-Dustin Benedict
Unread 02-02-2012, 20:17
Nikkocharger's Avatar
Nikkocharger Nikkocharger is offline
The R/C'er
AKA: Dontae
FRC #3398 (Crushing Crusaders)
Nikkocharger will become famous soon enoughNikkocharger will become famous soon enough
Yea we just bolted another c channel underneath the chassis like Mk.32 said but beware when cutting out new holes for a custom wheelbase make sure you get your measurements just right
Suddenly, a wild prototype appears!
Unread 02-02-2012, 21:13
Andrew Tucker
AKA: Andrew Tucker
Thank you for all the information my team and I really appreciate it!
