Go to Post Aha I just noticed you're from my team. --Petey - Petey [more]
Unread 02-02-2012, 11:46
bcharbonneau bcharbonneau is offline
None #1296 (Full Metal Jackets)
bcharbonneau is an unknown quantity at this point
Team 1296 Mecanum Bump Test
We tested our mecanum wheels over a 4 X 4 to see how they worked. So far it looks good. Let us know what you think. http://youtu.be/jl8pHpCjQtY
Unread 02-02-2012, 12:23
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Team 1296 Mecanum Bump Test
A few things you'll want to change:
-ballast the robot to full weight
-a 'real' barrier overall dimensions at 4"x6"
-metallic bump material with radiused corners (I think this will really impact the wheels' traction)
Otherwise it looks good, plenty of ground clearance!
Unread 02-02-2012, 12:39
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Thanks for the input. We are thinking the extra weight will help but are worried about the "real" radiused metal bump. The bump being an extra 2" wide should not be a problem though as the opening in the middle of the robot is 21". The bot will have a nice ramp lowering device but we wanted to make sure it goes over the bump just in case.
We had quit a few folks say that it would not go over and some who thought it too dangerous (including me) but those super-duty mecanums from AM are really tough and the angled front edge helps - so much for the common "mecanums can't go over the bump" theory!
Unread 02-02-2012, 12:49
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Im interested to see it with all the extra weight, because its going to change the force vectors on the angled wheel mounts.
Unread 02-02-2012, 12:51
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
True, but it will increase traction <fingers crossed>!
Unread 02-02-2012, 13:27
Ben27Lacrosse Ben27Lacrosse is offline
FRC #1296
Ben27Lacrosse can only hope to improve
I'm looking forward to more weight too, should make it easier more traction!
Unread 02-02-2012, 14:04
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Polymers as traction surfaces generally lose traction efficiency as normal force is increased. Search CD or any tire test data if you don't believe me. I would anticipate some specific traction (tractive force per unit weight) loss as you add on weight. You will have more total tractive force, but relatively more mass to move.
Unread 02-02-2012, 15:13
pfreivald's Avatar
AKA: Patrick Freivald
I'd be worried about repeatedly ramming my mecanum wheels into the bump... The AM HD's are quite nice, but they're not indestructible!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 02-02-2012, 15:57
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
The angled surface on the wheel assembly hits the bump first - it helps a little. And we don't plan to make a living going back and forth, just did not want to NOT be able to.
Unread 02-02-2012, 16:15
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Why would we not believe you?
Depends on the nature of BOTH surfaces of course but I'm sure you are basically correct and we have looked at the data. If we double the mass I expect a 25% reduction in the friction coefficient for urethane rubber. So I'm thinking the effect is (at worst) linear for the small increase in weight (and probably not that bad) and the bot will push its way over the bump at full weight - we'll see soon.
Unread 02-02-2012, 16:16
pfreivald's Avatar
Right on -- I couldn't see that on the video!
Team 1551
I write books, too!
Unread 02-02-2012, 16:32
Get to it Keith!
Unread 02-02-2012, 20:16
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
What I am worried about is that the wheels with lose its strength after hitting the steel bump a million times. Also you got over a wooden bump do you think there might be a difference between the steel and the wooden because they are two completely different materials?
Unread 02-02-2012, 21:44
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
We are thinking the wheels will hold up but the metal bump is worrisome.
Unread 02-02-2012, 21:52
Kyler Hagler's Avatar
Kyler Hagler Kyler Hagler is offline
Jack of all trades
Kyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura about
Man that robot looks sexy!!
Kyler Hagler - 3310 Alumni/Mentor
Black Hawk Robotics Team 3310
2012 Dallas West Regional Winner
2013 Dallas Regional Winner
2014 Colorado Regional Winner
2015 Hub City Regional Winner
2016 Arkansas Regional Winner
2016 Hub City Regional Winner
Http://Team3310.com
