Go to Post You know you're addicted to FIRST when to you: 4's company, 5's a crowd, and 6 is someone off-sides. - Tetraman [more]
Unread 02-02-2012, 21:51
Austinh100's Avatar
Austinh100 Austinh100 is offline
FRC #3695 (Foximus-Prime)
Austinh100 is an unknown quantity at this point
Sun Gear Question
Using a am-0912 we cannot get theSun Gear to slide on to the motor shaft, any suggestions?
Unread 02-02-2012, 22:14
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Sun Gear Question
People have had success heating up the gear and then pressing it on the shaft.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 02-02-2012, 22:25
Drivencrazy's Avatar
Drivencrazy Drivencrazy is offline
AKA: Clint Ott
FRC #1619
Drivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant futureDrivencrazy has a brilliant future
When we have had trouble in the past we use a fine grit emery cloth to very lightly sand down the beginning of the shaft to help guide the gear on. Be sure to not sand too much or the gear will not grip well.
Unread 02-02-2012, 22:26
CrashTestPilot's Avatar
CrashTestPilot CrashTestPilot is offline
AKA: Rafal Myslak
FRC #2338 (Gear It Forward)
CrashTestPilot is an unknown quantity at this point
I have not done this personally but take a look at this video
http://www.youtube.com/watch?v=GDxEK...ature=youtu.be
I got it from a thread that was here just few days ago. Search for How to remove pinion gear.
Unread 03-02-2012, 00:01
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
On the back of these motors, the drive shaft is exposed just a little bit. This shaft runs all the way through the motor and is the same one that the gear will be pressed to. The reason why its this way is so that you can use an arbor press to press the gear on. As mentioned before, heating it helps, but after doing six of these today (no joke http://www.chiefdelphi.com/forums/sh...66#post1118966) I found that it is easier to do it without the torch and use the free hand to line everything up.
It is also a good idea to cut a piece of sheet metal (~50 thou thickness works well) to use as a spacer while pressing the gear on.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 03-02-2012, 00:23
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If you are a team that doesn't have an arbor press, you can press pinions on using a vise if you are careful.
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-02-2012, 00:41
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
This is exactly what we did. With the same gear and same motor the OP was referring to. Works like a charm if you're careful. I'd suggest using a larger vise that's hard-mounted. We used the corner of the vise to ensure that only the shaft was in contact with the vise, and not motor body, spade connectors, or bearing.
Unread 03-02-2012, 07:28
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC2168 did this last night, we used the vice on the mill down in the shop, as we know that the sides should be parallel and it is not going to move while we are working.
