Go to Post No amount of sleep beforehand will make up or prepare you for the lack of sleep you will receive during build season. - Dan Petrovic [more]
Unread 02-02-2012, 22:22
RB73 RB73 is offline
FRC #2866
RB73 is an unknown quantity at this point
Bridge angle?
Does anyone know the angle that the bridge makes with the ground when it is lowered?
Unread 02-02-2012, 22:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Bridge angle?
Nope...but it's probably related to it's center height of 12" and the distance from the edge to the center of 44". That and a little trig will get you withing a degree or two?
Unread 02-02-2012, 23:02
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Bridge angle?
I believe it was 15 degrees, but yeah, just take the arcsine (alternatively, the chamfer on the bridge pieces is also indicative of this angle).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 02-02-2012, 23:04
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Bridge angle?
The angle is somewhere in the neighborhood of 16.5 degrees.
Unread 03-02-2012, 07:11
FRC #2866
Re: Bridge angle?
The problem I was having is that the bridge doesn't rotate on a central axle, it tips on a block underneath of it.
Unread 03-02-2012, 08:54
MrForbes's Avatar
AKA: Jim
Re: Bridge angle?
Yup, so it's a little steeper. The hypotenuse at the 12" height is actually less than 44", and the amount less is hard to figure out in my head....I'd have to make a sketch...
or put a protractor on the bridge we made
Unread 03-02-2012, 09:06
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Bridge angle?
Ideally it's 15.38 degrees, but in the past, measurements of height of game field objects have been made from the floor, before the rug is laid down. Either way, it's in the realm of 15 degrees.
