Go to Post Even better than any [book] is simply becoming an active member of the Chief Delphi forums. Where do you think I got everything I know? - sanddrag [more]
Unread 02-02-2012, 23:33
Re: Missing DPAD axis
Originally Posted by neal View Post
Not sure if it would work, but you can always extend classes. kJoystickAxes in DriverStation currently defines that there are only 6 axis. You could either change it in there (make sure to change it again after a NetBeans update) or you could extend it and use it. Then you can just call getRawAxis(7).
The driver station only transmits 6 axes, so this won't work.
