Go to Post I'm always shocked when I see wiring having a bad hair day. - JaneYoung [more]
Unread 03-02-2012, 03:10
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
pic: Team 192 teaser
Unread 03-02-2012, 03:12
Boomster Boomster is offline
Boomster is an unknown quantity at this point
Re: pic: Team 192 teaser
Why are your CIMS sideways? Considering how difficult bevel gears are to manage, why would you do this instead of a typical spur gear based gearbox?
Unread 03-02-2012, 03:25
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
I think it is a worm gearbox.
The sideways cims eat up less space into the middle of the chassis making it a more compact setup.
Very nice.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 03-02-2012, 04:51
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Is that a gearbox-less drill I see in the background?
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 03-02-2012, 05:20
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
We like to cut Black and Decker drills in half and wire up anderson connectors to them to drive various motors (sometimes including the motor cut off the drill) for quick testing. Done right, the direction switch stays intact too, but sawing a drill in half isn't always easy to get right. They really get a lot of use once we have motors mounted to things, but don't have access/time for a control system.
Unread 03-02-2012, 08:51
Andrew Lawrence
Posts: n/a
So 192 has worm gearboxes... That's interesting! Can't wait for SVR and CVR if you're going!
Unread 09-02-2012, 00:08
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
The gear box was project of some of the students. They did the research and design by themselves. It looks better in person then in the picture.
For over a decade 192 has used 12 volt battery drills as power sources. This gives you a variable voltage reversible polarity hand held power source. We use Anderson power pole connectors on all of our motors. This allows us to run any motor without powering the whole robot or to run tests of components on the work bench. Two will run the four motor drive train for a short bit. It is best if you put at least a one foot lead for the connectors. The drill motors make great motors for design projects during the fall.
