Go to Post I think rovers on Mars are way cool but you won't get a crowd of enthusiastic participants cheering as they trudge 150 meters a day. - Andrew Schuetze [more]
Unread 03-02-2012, 07:35
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Team 1296 Mecanum Bump Test
Originally Posted by wireties View Post
Why would we not believe you?
It was meant as the 'royal you' as every time this topic of polymer load/pressure sensitivity comes up someone inevitably goes: "well that's not what my physics teacher says!" and I might be a little tired of making the same points over and over
Unread 03-02-2012, 09:34
pfreivald's Avatar
AKA: Patrick Freivald
As a physics teacher, I use the disclaimer that the line "...but it's really more complicated than that!" is implicit at the end of every explanation.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 03-02-2012, 10:13
Generator of Entropy
FRC #2973 (The Mad Rockers)
Polymers as traction surfaces generally lose traction efficiency as normal force is increased. Search CD or any tire test data if you don't believe me. I would anticipate some specific traction (tractive force per unit weight) loss as you add on weight. You will have more total tractive force, but relatively more mass to move.
While that may be true for "frictional traction", it's not necessarily true on carpet where a considerable amount of the tractive force is actually a normal force between projections on the wheels and fibers on the carpet. The reason brekoflex type belting and some mechanums get such good traction is the amount of embedded overlap when edges on the wheel surface dig down into the carpet, which is a function of weight but more importantly an inverse function of contact area. Our previous testing and data has shown this.
Unread 03-02-2012, 10:25
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Some teams have run experiments showing that wider wheels, i.e. ones with more ground contact, get better grip. A big part of this is that the 'embedded overlap' interface you talk about becomes saturated at a certain contact pressure (the carpet and tread have finite depth) and as pressure increases above this threshold the coefficient of friction drops off. Even before the interface is totally saturated the coefficient of friction generally drops off slightly with load because the carpet/tread presses together more firmly, making it more difficult for the tread to embed further.
This analysis is based on my knowledge of tire-road interfaces and what I've learned from reading many CD threads on the subject.
One thread with related discussion is here: http://www.chiefdelphi.com/forums/sh...ad.php?t=98664
Unread 03-02-2012, 10:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Is that a normal 3.5" thick 4x4? Or is it a special 4" thick 4x4?
If I were you, I'd build a short section of "real" barrier, put it on carpet, and try it. You might find that it's a bit harder on the robot than it looks in the video with the 4x4.
Unread 03-02-2012, 10:57
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
normal, so not quite 4" tall - we are quite worried about a "real" barrier and are looking to build one, the 4x4 test was kind of impromptu - the bot has did well so hopefully things go well with the real barrier
how are teams building a real barrier?
Unread 06-02-2012, 14:07
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
Ours isnt real, but we put some 2x4's together and fleshed out the remainder with 1/2 inch plywood. I realize it isn't metal, but it gives us the right dimensions.
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
Unread 08-02-2012, 12:00
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
We just did the same thing and it still goes over. I am worried about the metal version. We'll try that this weekend.
Unread 08-02-2012, 12:34
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
So you guys are building a metal one? may have to make a visit then
Unread 08-02-2012, 14:52
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Nope, thinking about finding out where LM sets up a complete field.
