Go to Post I say: Chutes & Ladders in FRC 2008! - petek [more]
Unread 03-02-2012, 07:51
WarehouseCrew WarehouseCrew is offline
FRC #3299 (Warehouse Crew)
Team Role: Parent
WarehouseCrew is an unknown quantity at this point
Frame perimeter "minor protrusions"?
Can someone help me understand the frame perimeter rule (eg. "minor protrusions" under 1/4" under R01-2)?
Our robot will be using C channel. We will have a lower level frame for mounting wheels and directly above an upper frame (also C channel) for mounting bumper, manipulator, etc.
1. Gusset plate - Would a gusset plate (1/16" steel) and bolt head that combined are less than 1/4" be legal according rule R01-2? We would like to use steel gusset plates on the exterior of our frame to create a rigid connection between the lower and upper frame. If the C Channel (that defines frame perimeter) is oriented so the open part of the C is facing the interior of the robot, the exterior surface makes a good surface to attach the gusset plates on both upper and lower frame.
2.C Channel Orientation - If gusset plate is not allowed on exterior of frame, would a C Channel oriented with the open section facing the exterior of the robot (bumper would be mounted to this) be legal?
Unread 03-02-2012, 08:20
Team Role: Parent
Re: Frame perimeter "minor protrusions"?
We will be cutting and drilling on Saturday, so I hope someone can clarify this rule for me. Thanks.
Unread 03-02-2012, 09:11
It sounds to me like the gusset plate would define the Frame Perimeter.
Remember that "Frame Perimeter" doesn't mean "the perimeter of the piece of the robot you call the frame". It's specifically defined as the polygon defined by the outermost set of vertices of the robot within the Bumper Zone. If your gusset plate is between 2 and 10 inches off the floor, it's going to contribute to those vertices.
Unread 03-02-2012, 09:20
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I agree with Alan. It sounds like the gusset plates are behind the bumpers, so they would define the frame perimeter and the slight protrusions would be allowed in the bumper zone.
Two things to keep in mind:
1) Make sure the gusset plate + bolt heads don't push the bumpers out enough that you have more than 1/4" gap between the bumpers and the c-channel along the rest of the bumper length, or the bumpers will be considered unsupported and need support every 8 inches. If they do, you are allowed to place small relief areas in the bumper plywood to clear the bolt heads.
2) The bolt heads can protrude beyond the frame perimeter, but they still have to be inside the maximum allowed dimensions of the overall robot (they still have to fit in the sizing box).
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 03-02-2012, 10:42
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Also realize that the dimensions of everything that remains after you take off your bumpers (including minor protrusions of things fastening your gusset plates) must fit in the 28x38 sizing box. The minor protrusions clause relates to the bumper/robot interface, but gives you no grace on the 28x38 size limitations.
This is the reason most teams size their frame perimeter at 27x37 or so maximum. This also helps for cases where the upper parts of your robot which may be wide and 'out of square' since it has to fit inside the box also.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 03-02-2012, 17:45
Team Role: Parent
Thanks. Our frame is 1" shorter than maximum allowed (eg. 27" x 27").
Didn't want to start cutting based upon an incorrect assumption (eg. gusset plate and bolt head less than 1/4" allowed on exterior of C channel) and find out our robot doesn't pass inspection.
Unread 03-02-2012, 18:18
nitneylion452's Avatar
AKA: Joe Lee
Is your robot a 27x27 square? If so, you can extend one of those dimensions an additional 10".
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 03-02-2012, 19:25
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
I think he means 27"x37".
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 03-02-2012, 19:56
Team Role: Parent
Yes. Our frame is 27" by 37".
Unread 03-02-2012, 20:26
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We've built a subframe spaced off of the main frame with aluminum tubing as spacers/standoffs and 1/4" threaded rod holding it together. Sorry I don't have any pics, but it's strong, easier to cut than gussets, and the frame will remain flat to make it easier to mount bumpers.
