Go to Post It is one thing to be a great designer, it is another thing to be able to explain what you did, how things work, and why things happen. - Andy Baker [more]
Unread 03-02-2012, 10:59
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
pic: FRC 1086 Final Robot: 2012
Unread 03-02-2012, 11:00
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: FRC 1086 Final Robot: 2012
Looks spectacular, see you at Virginia.
Unread 03-02-2012, 11:54
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Your robot looks better than ours, at this point...
However, your appendage looks illegal, as it appears to be two appendages when it first crosses the frame perimeter. That's a no-no, according to the GDC Q&A on 2012-02-01
Q: Our question is similar to FRC1540. We want to put surgical tubing "whips" on a roller located at the frame perimeter. When this rotates the whips will extend beyond the frame perimeter. Is each "whip" its own apendage or is the assembly considered one appendage?
A: If multiple items exit the Frame Perimeter and are not contiguous outside the Frame Perimeter, they are considered multiple appendages.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 03-02-2012, 11:57
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
NOTE: *Actual Robot in upper right corner...
2011 Record (11-3-0)
Unread 03-02-2012, 12:07
wilsonmw04's Avatar
Coach
There are some interesting hints as to what we are going to be doing if you have a keen eye...
Unread 03-02-2012, 13:33
LightSpeedIII's Avatar
LightSpeedIII LightSpeedIII is offline
Ludicrous Speed!
AKA: Bradley J.
LightSpeedIII is an unknown quantity at this point
When the appendage fully extends, they are connected outside of the frame
Unread 03-02-2012, 13:35
Flywheel Police
Looks like angles on the chassis to traverse the barrier, what about the turret? Do you plan on rotating it or fixing it and using the drive train to rotate it? Did you guys ever get your cRio problems figured out last year? It was a shame to see such a nice looking bot with so much bad luck.
Unread 03-02-2012, 13:44
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
You guys know how hard it is to powder coat wood, right?
I was expecting something in the vein of your 2009 robot. Looks like this one won't disappoint either
Unread 03-02-2012, 13:51
Therein lies the problem. When the appendage fully extends, it's good. While it is in the process of extending, at least looking at current Q&A interpretations, it's 2 appendages, and you're only allowed 1. There is more discussion at http://www.chiefdelphi.com/forums/sh...d.php?t=100696.
Unread 03-02-2012, 14:07
PatrickBrew1086's Avatar
PatrickBrew1086 PatrickBrew1086 is offline
FRC #0401 (Copperhead Robotics)
PatrickBrew1086 will become famous soon enoughPatrickBrew1086 will become famous soon enough
We actually just talked about this issue at lunch today; we are planning on posting on the Q & A a question about if that instance where the rod that connects the two is behind the bumper but everything else is outside the bumpers will be forgiven. If not, we'll work on re-drawing the part so it is within the rules.
There are angles on the real chassis, the one in the top right corner, for bump traversing with ease. It is a design that we modified from our 2010 robot. We are planning, after many long design and strategy discussions, on not having a turret this year. Pinpointing the issue with our cRio was an issue but we completely replaced everything between the code and the robot. So we have a new computer to download code from (including code in a different language from last year), ethernet tether, bridge, power converter, and cRio (4 slot). Last year was rough robot wise but it certainly wasn't all bad luck that kept the robot stagnant.
Patrick Brew
Unread 03-02-2012, 14:51
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Bears a striking resemblance to ours! The shooter is virtually the same!
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 03-02-2012, 22:59
nahstobor's Avatar
nahstobor nahstobor is offline
EWCP
AKA: Shan (pronounced Shawn)
FRC #2733 (Pigmice), FRC #612 (Chantilly Robotics)
nahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond repute
Looks like your 2012 drivetrain is in the upper right hand corner of the picture.
Unread 03-02-2012, 23:03
Looks like the practice one. I think I saw a corner of the real one in the lower right.
Unread 03-02-2012, 23:26
wilsonmw04's Avatar
Coach
Two points for Eric! Anything else you notice?
We have a little twist on our shooter this year. (no pun intended)
Unread 03-02-2012, 23:36
Yeah, you're bluffing about not having wheels. The shooter base has 4 (not counting shooter wheels), which don't look like they're powered yet, and that other chassis I mentioned is levitating (or has some form of wheels on it).
