Go to Post It would be wise to consider the reasoning behind the statement rather than the statement itself. Sometimes they are right... other times their statement is incomplete... and other times they really do have no clue what they are talking about. - dtengineering [more]
Go Back   Chief Delphi > Technical > CAD
Unread 03-02-2012, 17:27
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
How to CAD a sprocket.
Hello all,
I am in need to create a 35chain sprocket with an 16.5 inch outside diameter.
What would be be the proper way to create such a sprocket in CAD?
I mainly use Solidworks.
Thanks.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 03-02-2012, 18:55
Aren Siekmeier's Avatar
on walkabout
Re: How to CAD a sprocket.
That's a tad large...
In Solidworks, you can use the Toolbox to configure parts such as bearings, sprockets, gears, pulleys, fasteners, and more from some template provided by Solidworks. Click the Design Library tab on the right and select Toolbox, Click "Add in now" and browse to the part you want to create, right click and say create part, which you can then configure with the panel on the left. This will create a new part that will probably want to save somewhere you can find it again.
