Go to Post Bring on the competition! And of course the dancing. :D - booton [more]
Unread 03-02-2012, 18:49
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Encoder Wiring Help Needed
The encoders in the KOP have 4 wires. +5, GND, A and B. You can connect the encoders either to the Jaguars directly (if you are using the Jaguars as your motor controllers) or to the digital input channels on the digital sidecar.
For connecting to the Jaguar, crimp a 5-pin header connector with the 4 wires ("+" goes to +5, "-" goes to GND, "A" goes to A and "B" goes to B, "I" has no connection).
If connecting to the cRIO, each encoder needs two digital channels. On the first digital channel, "+" goes to +5 (red), "Gnd" goes to "GND" (black) and "A" goes to signal (white). For the second digital channel, "B" goes to signal (white).
