Go to Post theres no such thing as the best robot...cuz every robot is the best :D - [more]
Unread 03-02-2012, 18:29
gurdy2 gurdy2 is offline
FRC #1325
gurdy2 is an unknown quantity at this point
Encoder Wiring Help Needed
This is our team's first time using encoders and we are encountering issues as to where on the robot/cRio we should be connecting the encoder wires. If anyone can please help and show what part of the robot we should wire our encoders to (electrically) and more specifically how.
Please Note: we are using the kit of parts E4p encoders for our shooter.
Thanks in advance!
Unread 03-02-2012, 18:49
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Encoder Wiring Help Needed
The encoders in the KOP have 4 wires. +5, GND, A and B. You can connect the encoders either to the Jaguars directly (if you are using the Jaguars as your motor controllers) or to the digital input channels on the digital sidecar.
For connecting to the Jaguar, crimp a 5-pin header connector with the 4 wires ("+" goes to +5, "-" goes to GND, "A" goes to A and "B" goes to B, "I" has no connection).
If connecting to the cRIO, each encoder needs two digital channels. On the first digital channel, "+" goes to +5 (red), "Gnd" goes to "GND" (black) and "A" goes to signal (white). For the second digital channel, "B" goes to signal (white).
Unread 03-02-2012, 18:58
nitneylion452's Avatar
AKA: Joe Lee
Is there any advantage to wiring the encoders one way over the other? I only ask because we used encoders last year and had no idea they could go to the jags.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 03-02-2012, 19:00
mikets's Avatar
Software Engineer
If you wire the encoders to the Jags, you must use CAN or you can't access them. The benefits are pretty much the CAN versus PWM arguments such as: cleaner wiring, not taking 2 digital channels per encoder, can optionally use the Jag's built-in PID control etc.
Unread 03-02-2012, 19:22
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Is there a point to access both channels?
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 03-02-2012, 19:25
mikets's Avatar
Software Engineer
Don't understand your question. What channels? Are you talking about the two digital input channels? If so, you need two channels per encoder in order to determine the position/speed as well as the direction of the rotation. the FPGA will handle the two channels and give you the resulting count and direction.
Unread 03-02-2012, 19:27
AKA: Pat Miller
Yes that's what I mean. But if you use PWM and use either A or B channel is it less accurate?
Unread 03-02-2012, 19:28
What are you going to use it for?
Unread 03-02-2012, 19:33
AKA: Pat Miller
Just as a general question. But I may have miss read he post. Do A and B both go to white or is it one or the other?
mikets's Avatar
Software Engineer
It's not a matter of accuracy, without two channels, it won't know the direction of rotation. Besides, unless you are writing code to "count" the pulses from the one digital channel yourself, the Encoder module provided by the WPI library expects both A and B channels.
Encoder(UINT32 aChannel, UINT32 bChannel, bool reverseDirection=false, EncodingType encodingType = k4X);
Unread 03-02-2012, 19:36
mikets's Avatar
Software Engineer
A and B goes to the white of a different digital input channel.
Unread 03-02-2012, 19:37
Are you saying the FPGA running the FRC firmware cannot be configured to count pulses on one channel and make that count available to the CPU? Or just that the high-level encoder class is not designed to do that?
Unread 03-02-2012, 19:40
AKA: Pat Miller
Makes sense to me. My team since i've been involved, never really used anything more than just a limit switch. So I just figured I ask for future.
Unread 03-02-2012, 19:44
mikets's Avatar
Software Engineer
I am not sure if it can or cannot. After all, the FPGA is programmable, the firmware can configure it anyway it could. My understanding is that the FPGA implements the counter for the encoders and the Encoder module in the WPI library is expecting both channel A and B. There is no method in the Encoder module that accepts only one channel. So I am making a speculation that it does not support one channel. However, it is probably possible to implement a software counter. But I don't know the innards of the FPGA enough to be able to do that.
Makes sense to me.
You linked your response to my two-question post#12. Was that intentional? If so, not sure what part made sense to you.
