Go to Post Like a moth to a flame, true FIRSTers are attracted by the Victor instead of the Banner. - Rich Wong [more]
Unread 03-02-2012, 18:09
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
single lline encoder on Jags
can we use a single line encoder like a gear tooth encoder or an optical encoder with the Jags?
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 03-02-2012, 18:19
mikets's Avatar
mikets mikets is online now
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: single lline encoder on Jags
I don't see why not as long as you tell the Jag "number of lines per revolution".
Unread 03-02-2012, 18:39
Have you tried this?
Unread 03-02-2012, 18:51
mikets's Avatar
Software Engineer
We have connected our 250-line encoders to the Jags. They worked as expected. We are doing speed control on it although we did not use the Jaguar's built-in PID. We used our own PID controller library in the cRIO.
Unread 03-02-2012, 18:56
Ah! You mean lines as in counts, but he means lines as in wires.
Unread 03-02-2012, 18:57
Did you connect both channels? Or just one (the OP's question).
Am I understanding correctly: You connected the encoder to the Jag, then using CAN you read the speed from the Jag, then used that speed as the feedback to a PID on cRIO, then used the cRIO's PID output to command the Jag?
Unread 03-02-2012, 19:02
According to the jaguar getting started guide:
Speed control can be implemented with either an encoder or with a simple tachometer sensor. If a tachometer sensor is used (such as a gear-tooth sensor), then the signal should be connected to the Encoder ‘A’ input signal, with the ‘B’ and ‘I’ input left unconnected.
There is no mention of the same thing in position mode. I have not tried it in either mode.
Unread 03-02-2012, 19:05
With a single channel tach input, the Jag cannot tell what the direction is. So position control would be problematic.
Unread 03-02-2012, 19:06
mikets's Avatar
Software Engineer
I am not sure I understand your question. Are you asking if we connected both A and B? If so, yes.
Yes, that's correct. We call the Jag to read the speed and use that as the Input to our PID controller on the cRIO. By doing so, we can change the PID algorithm to give us a stable speed control.
Unread 03-02-2012, 19:11
Yes, that's what I was asking, because I think that's what the OP was asking: whether or not it would work with one-channel input (rather than quadrature). Joe just answered that question affirmatively. The single channel must go to the A channel input.
Unread 03-02-2012, 19:13
Interesting. Can you read the speed from the Jag, compute the new output on the cRIO, and issue a new command to the Jag, all within the same TeleOp cycle?
mikets's Avatar
Software Engineer
Sorry for the confusion, I was answering the second part of his question whether I can use an optical encoder for which I assume is the KOP encoder.
Unread 03-02-2012, 19:15
mikets's Avatar
Software Engineer
Yes, we have achieved pretty stable speed control with it.
Unread 07-02-2012, 21:09
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Interesting.
We haven't been getting a reliable reading from the Jag when the sprocket is stationary. What language are you using (we've seen some unimplemented features in Java in previous years).
Thanks.
Unread 07-02-2012, 21:58
mikets's Avatar
Software Engineer
We are using Wind River C++. We just call CANJaguar::GetSpeed().
