Go to Post Nobody wins a Regional on Thursday. - Bill Moore [more]
Unread 03-02-2012, 19:47
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
Re: Encoder Wiring Help Needed
I dont recall doing that, but no it wasn't to your two part question.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 03-02-2012, 19:48
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Wait...
I just found a different class module (GearTooth class). This one accepts one channel. So it does support counting one channel. I suppose you can connect the A channel to one digital input and use the GearTooth class to access the count.
Unread 03-02-2012, 19:51
AKA: Pat Miller
To honest with you I know nothing about code. The most i know is that we use Java lol. I'm more of a mechanical/ electrical guy.
Unread 03-02-2012, 19:55
mikets's Avatar
Software Engineer
Interesting...
From reading the source code of the GearTooth class, it seems the GearTooth sensor can even tell the direction. It supports different pulse widths on different directions. I wonder how does that work? But I am sure it is only specific to the GearTooth sensor. If you use one channel of the optical encoder, since the pulse width doesn't change in both direction (except for changing speed), it cannot decode the direction from the pulse width.
Originally Posted by mikets View Post
I am not sure if it can or cannot. After all, the FPGA is programmable, the firmware can configure it anyway it could. My understanding is that the FPGA implements the counter for the encoders and the Encoder module in the WPI library is expecting both channel A and B. There is no method in the Encoder module that accepts only one channel. So I am making a speculation that it does not support one channel. However, it is probably possible to implement a software counter. But I don't know the innards of the FPGA enough to be able to do that.
Just found this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=101587
Unread 03-02-2012, 19:58
mikets's Avatar
Software Engineer
Yep, there is also a counter class that can be used for this purpose.
Unread 03-02-2012, 20:01
I am assuming that the counting is being done by the FPGA hardware. Otherwise you'd swamp the cRIO with interrupts.
Unread 03-02-2012, 20:03
mikets's Avatar
Software Engineer
Yep, the counting is done by the FPGA.
Unread 03-02-2012, 20:47
Does it say that explicitly in one of the documents you've just been reading?
Unread 04-02-2012, 06:46
mikets's Avatar
Software Engineer
It's in the source code of counter.cpp. It's accessing the FPGA all over.
Unread 04-02-2012, 11:26
jmailhot jmailhot is offline
FRC #0303 (Panther Robotics)
jmailhot is an unknown quantity at this point
Another issue with encoders to keep in mind is the "sense" of forward and backwards. Especially if using the encoders with jaguar PID loops, but even with cRIO PID loops, the encoders need to be increasing when the motor is going forward, and the control input sense of forward needs to match the encoder. And the jaguar's sense of positive voltage needs to match also. You may need to reverse the A and B lines of the encoder, or the polarity of the motor, to get these things all having the same definition of "forward". If you add limit switches to the mix, the forward and reverse limit switches must also correspond.
Unread 04-02-2012, 13:53
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Very timely discussion. I am going to make the assumption the LabView VIs associated with the counter implement this class for us to use to count shooter revolutions.
Thanks guys.
Unread 04-02-2012, 16:14
gnichols gnichols is offline
FRC #3862
gnichols is an unknown quantity at this point
Not sure where to go. I have wired these encoders using the 2 channels on the sidecar. When I do, the robot goes nuts. It spins one side drive backwards and the second side does nothing and never works. Have wired +5, gnd, signal A to first channel and signal b to second channel on both sides. Anyone have an explanation as to what is going on.
Unread 04-02-2012, 18:12
AKA: Mr Tanguay
Thanks guys.
An Update:
For you Labview programmers only interested in looking at one input to count pulses to determine the rate of rotation, the WPI counter library works great. Just make sure you take the time to read the help file on the counter VIs thoroughly.
When I got to the shop earlier today the team programmer complained that the software based counter he had built couldn't keep up at high motor speeds. I explained how the FPGA offloaded this work to the hardware and the counter VIs in the WPI library took advantage of this capability. We tried them and they worked all the way up to the 4000 RPM speed with no problem. We found it helpful to use one of the low-pass filters from the PID library.
Unread 04-02-2012, 20:31
What is your program doing to control the drive motors? Are the encoder readings used to compute the commanded motor power?
