Go to Post No one shall stand between me and my sleep. - Adam Y. [more]
Unread 03-02-2012, 19:53
CRLS97 CRLS97 is offline
FRC #0097
CRLS97 is an unknown quantity at this point
Question Encoder Trouble
Hey CD,
I've worked with an encoder last year without any troubles, but I can't seem to figure out what's wrong this year.
I have the 8-slot cRio reconfigured and modules swapped (from last years positions) to what they should be as noted by FIRST. I tested with the new ribbon cable and the old thick cable (from cRio to digital sidecar).
Our robot is near-fully functional. All the PWM signals work great. Analog works, etc. The trouble is the digital inputs and it's not just the specific one on the bot because I tried with a couple. I wired up an encoder (two of them actually and I'm 101% sure the wiring was correct (I checked multiple times and then with the help of a mentor used an oscilloscope to make sure the encoders were functional as well). Even tried hooking up our old robots encoders to the sidecar and still no luck-
Our code gave no feedback from the encoders. They were initialized properly and started properly so I'm sure nothing is wrong with code. Then I tried the FRC LabVIEW Motor with encoder example and ran it. Motor outputs are fine but the encoder gave feedback this time. However, what happened is that it went from 0 to 0.003 something and back to 0, continually oscillating between the two whenever there was an output to the motor (and the shaft was actually spinning). At the bottom of the example the encoder alarm is always: "stopped" rather than moving.
Does anyone have any clue to what may be wrong or what I'm doing wrong? The digital sidecar is plugged into module 2 of the cRio, recognized as Digital Module 1 in LabVIEW. Any help is greatly appreciated
