Go to Post No matter what happens to the robot we learned our lesson and we had fun. That's what matters. - David Guzman [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 02-02-2012, 18:36
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Who is using 10" or 8" Pneumatic Wheels
AM sells some (correction: sells 8" ones). You can buy them at hardware stores. They are used on dollies etc.
Just wondering how easy the robot is to turn ? Using them on a long robot or wide robot or smaller than legal footprint robot ? What about the bump ? Any testing with a full weight 145 lbs robot (including battery and bumpers or equivalent weights) ?
Unread 02-02-2012, 18:38
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Who is using 10" Pneumatic Wheels
You cannot buy 10inch wheels off AM as far as I know...
We got a set from SkyWayWheels, for pretty cheap with a FIRST discount.
Currently we are machining out hubs for them to be able to mount sprockets on, I will post back when we get a driving base with them set up.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 02-02-2012, 18:59
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Team 1247 is using 10 inch pneumatic wheels, though they are designed for wheel barrows. Half of them are even gold rimmed! In all seriousness, the robot is having a bit difficulty turning, and the voltage actually has to be ramped while turning because the breakers pop from the stall current :/
"No, you can't use the Kinect to do pelvic thrusts."
Unread 02-02-2012, 19:02
Mk.32's Avatar
AKA: Mark
What kind of set up do you have? 4 Wheel? 6 Wheel? and how much drop if any?
Unread 02-02-2012, 23:32
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Team 1339 is using wheels we got at harbor freight. They are heavy but may have some offsetting advantages. They sure do look cool. We have had little drive time so far as we had to machine hubs and blew out the crio. I'll keep you updated.
Unread 03-02-2012, 00:10
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
We're using 7.5 inch wheels (they said 8 inch...) because the 10 inch wheels were too heavy. We put omni wheels on the back, and it obviously turns great. However, when we tried it with the standard rubber wheels, the chassis would just bow up and it wouldn't move at all when trying to turn.
Unread 03-02-2012, 10:57
2544HCRC's Avatar
2544HCRC 2544HCRC is offline
FRC #2544 (HCRC)
2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about
We are using a 9" wheel from a supplier of scooter wheels and parts. They are about $40 each, come with the aluminum wheel, inner tube, tire, and a #25 pitch sprocket, and 10mm bearings installed. I'm a bit concerned with the turning. We are using a 6wd setup with a center drop.
Unread 03-02-2012, 19:54
mayde's Avatar
mayde mayde is offline
Team Captain / Pirate Queen
AKA: Mayde Smith
FRC #2865 (Roboteknix)
mayde is on a distinguished road
Send a message via MSN to mayde
If you have a 6 wheel chassis with 2 sets of omniwheels and 1 set of the pneumatic kind, turning isn't a problem at all.. our baby is drifting like vin diesel in an action movie. I'm not sure how an all pneumatic wheeled drive train would work out, however.
Surprise.
Roboteknix 2865;
2010 Spirit- Portland Autodesk Regional
2011 Safety Captain - Seattle Regional
2012 Team Captain- Cheney (Spokane) Regional
Unread 03-02-2012, 20:36
jp1247's Avatar
FRC #1247 (ROK BOT)
We are using 4 wheels, and I'm not quite sure what you mean by "drop".
Unread 03-02-2012, 20:39
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
We are using eight 6" Pneumatic wheels.
Unread 03-02-2012, 21:48
onecoolc's Avatar
onecoolc onecoolc is offline
AKA: Cris
no team (Roboteknix Alumni)
onecoolc has much to be proud ofonecoolc has much to be proud ofonecoolc has much to be proud ofonecoolc has much to be proud ofonecoolc has much to be proud ofonecoolc has much to be proud ofonecoolc has much to be proud ofonecoolc has much to be proud ofonecoolc has much to be proud ofonecoolc has much to be proud of
For clarification, we're using the Andymark 8" Pneumatic wheels in the center of a six wheel drive, with 8" Dualie Omni Wheels on both the front and back (also from Andymark).
And, yeah, she spins like a top. So far we've only tested the 'bot on linoleum, and she tends to drift quite a bit, but that won't be as big of an issue on carpet. With some practice the drive team should be able to handle it fine.
2008, 2009 - Team 1432, Mars Metal Beavers, Team Spirit : Oregon Regional
2010 - Team 2865, Roboteknix, Head Scout and Awards : Oregon Regional and Championships
2011 - Team 2865, Roboteknix, Rules Master : Seattle Olympic Regional
2012 - Team 2865, Roboteknix, Team Captain : Spokane Regional
2013 - Unaffiliated : Volunteer for Spokane Regional
2015 - Unaffiliated : Volunteer for Kickoff & West Valley Regional
Unread 04-02-2012, 11:28
mrnoble's Avatar
teacher/coach
We are trying a slightly different configuration this year; six wheels (10" with a 1/4" drop in the center), driving only the rear and middle. We have had success with using painter's tape to cover tread on the front wheels to avoid sticking in years past, and will probably do something like that again. We are doing a lot of testing today, so we'll see what happens.
Unread 04-02-2012, 12:19
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
We had 6 harbor freight wheels mounted and running and had no problem with turning with a 1/4" drop. We had planned on articulating the center wheels to allow for a stable shooting platform, but when we built the whole thing it turned out to be a little heavy.
We are now running two of our pneumatic wheels in the center and 2011 kop wheels front and rear. Looks like it should be about the same performance, but it doesn't look as mean. Plus it weighs 40 lbs less, which is good if we want to attach anything that can do minor tasks like perhaps picking up an 8" foam ball and shooting it.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 05-02-2012, 22:24
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
we're using 10" pneumatics from harbor freight. They are our two front drive wheels and we have 2 casters on the back of the robot.
it turns pretty well, but that's all due to the casters.
If it was 4 pneumatics I can't say I know what would happen.
However, we had a team member sit on the robot and we noticed it drives much better under weight (the tires get more contact in the floor when pressed down).
I'd also suggest wearing them out a bit so the tread is flatter and, again, gets more contact with the floor.
Unread 05-02-2012, 22:29
legogeek24's Avatar
legogeek24 legogeek24 is offline
AKA: Dirk
FRC #3562 (LiveWire)
legogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura about
We're using 8" pneumatic wheels, one in the center of each side of our frame. We'll be mounting casters on the front and back eventually, but just driving with the two wheels and nothing else, it handles great! We're flying right over the bump and climbing the bridge with no difficulty.
4 year FIRST alumnus and current MIT Computer Science student
Mentor for LiveWire 3562 and The Arabian Knights 4928
"1...2...3562!!!"
