Go to Post You win Worlds by innovation. You win Worlds by determination. You win Worlds by engineering a robot so solid, that it successfully completes the game. - Zach O [more]
Unread 03-02-2012, 20:52
DSager3 DSager3 is offline
FRC #1546
DSager3 is an unknown quantity at this point
Help Programming Our Shooter In LabView
Hi all, hope you can help.
Tonight my team finished construction of our elevator system and shooter. Our elevator is the popular poly cord run on pulleys design and our shooter (pictures attached) has one wheel powered by a BaneBot motor(not in the picture) and a controllable hood powered by a window motor. We are satisfied with its performance right now, but we think that if we were to mount the shooter on a lazy susan and use the camera to track the backboards and it automatically adjust the lazy susan and shooter hood accordingly, it would take our robot to the next level. Only problem is that our programmers are relatively inexperienced. We are programming in LabView and any help of how to code this function, or even where to being is greatly appreciated.
Thank you and best of luck to all teams.
-1546
ID:	11692  Click image for larger version
Unread 03-02-2012, 21:36
Re: Help Programming Our Shooter In LabView
I suggest you start with the Rectangular Target Processing example in LabVIEW. Once you have the camera detecting and tracking the target, you can try to use the measured position of the target to decide which way and how far to move your shooter's turntable.
Unread 03-02-2012, 23:58
pfreivald's Avatar
AKA: Patrick Freivald
I just learned that a good number of the features in the Vision Assistant are not supported if you have an 8-slot CRio, though... Which, judging by your team number, you have.
I have no idea what to do about it, unfortunately.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 04-02-2012, 03:17
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I have a couple questions for you to think about.
I don't see any feedback from your shooter (yet). Consider: how will you insure your shooter is running the speed you want?
Next, that window motor runs at around 80 rpm. That means it wants to rotate once a second. You have it direct driving your hood. Are you planning on having two hood positions, each using a positive stop? If not, you may be in trouble. It will be difficult for your human player to try to manipulate that hood to a precise angle while your robot is on the field without some type of automatic feedback.
The included rectangular vision example is a good start, though it is complex. You will also find an NI whitepaper on it's use here on Chiefdelphi.
Unread 04-02-2012, 07:29
The example that was mentioned works fine on the 8-slot, but as mentioned, some of the more advanced features were stripped out for space savings.
More Details:
Between the LV8.6 and LV2011 releases, the vision module grew by over 5MB. Many of those new features, and some of the existing ones were more for machine inspection than for robotics. The imaging tool installs the smaller, more stripped down, version of IMAQ on the 8-slot, and the complete edition on the 4-slot. There are some additional differences besides vision as well.
I don't have a complete list of what was removed, but we did our best to leave in a rich set for robotics applications. We received no negative feedback during beta, but if we discover that a feature is badly needed, we'll do our best to recompose it again.
Greg McKaskle
Unread 04-02-2012, 14:01
Larry Lewis's Avatar
Larry Lewis Larry Lewis is offline
The Spiky Hair Guy
FRC #1511 (Rolling Thunder)
Larry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to all
More Details:
Greg McKaskle
Greg,
Would you be able to help to provide a list of what the differences between the 8 slot and 4 slot installation or is there a way for teams to determine this? This would be useful to document for the teams that are using LabVIEW this year.
Larry Lewis
FIRST Team 1511 - Rolling Thunder
Team Leader
2013 - Present: Systems Engineer - Viewpoint Systems
2004 - 2013: Lead Test Engineer - Harris RF Communications
www.penfieldrobotics.com
Certified LabVIEW Architect
"I haven't failed, I've found 10,000 ways that don't work" ~Thomas Alva Edison
Unread 04-02-2012, 14:38
This isn't just a LV issue. The IMAQ library is shared by all languages. As I stated, I don't have exact symbols that were removed. I"m sure that the list of missing symbols can be built, but I don't have cRIOs with me at the moment.
Greg McKaskle
Unread 04-02-2012, 14:40
FRC #1546
Thank you all for your help! I'll relay the information to our programmers on Monday. In regards to the shooter, the hood is directly driven by the window motor and we plan on using two limit switches to limit the range of our hood. Also, our programmers drastically reduced the speed of the motor (not completely sure how they did it, I'm more of a mechanical guy) so the operator can control the hood angle more easily. If possible, we want to take out the human error of a person controlling the hood angle and have that done automatically.
Unread 05-02-2012, 11:22
I think part of the problem was that beta teams were mostly reconstituting old code (if they were testing vision at all). You use a lot more functions while developing and testing code then makes it into the final product. For this case, I'm not sure the beta test was a valid test.
Unread 05-02-2012, 14:27
pfreivald's Avatar
That appears to be the case here. Everything we've tried thus far failed to build... We spend almost two weeks uninstalling and reinstalling LabView, checking network connections and Windows updates, etc, etc, all thinking that the problem was on our end.
To find that the problem was both known and on NI's side of things is discouraging -- one would have hoped that functionality differences between versions would have been communicated...
Was it? Did we miss it somewhere?
Team 1551
I write books, too!
Unread 05-02-2012, 14:32
one4robots one4robots is offline
AKA: Vince Wagner
FRC #2530 (Inconceivable)
one4robots is on a distinguished road
Your design looks remarkably similar to ours! Great minds think alike! Our turret, angle of elevation, and speed of shooter will all be software controlled. Our programmers have been working on target recognition very hard, and I think they have it down. I'll mention this thread and have them comment.
It's Inconceivable!
2015 Wisconsin Regional Winner - Thanks 2826 and 2062!
2014 Wisconsin Regional Semi-finalist and Alliance Captain - Thanks 167 and 4296!
2014 MSHSL Finalist and Alliance Captain - Thanks 3018 and 4607!
2013 Northern Lights Gracious Professionalism Award
2012 MRI Champions - Thanks, 3883 and 3630!
2012 MSHSL State Tournament Semi-finalist
2012 10,000 Lakes Regional Finalist
2012 10,000 Lakes Regional Delphi Engineering Excellence Award
2012 Lake Superior Regional GM Industrial Design Award
2011 Minnesota Robotics Invitational (MRI) Champions - Thanks, 2052 and 2450!
2011 Inaugural Lake Superior Regional Finalist
2011 Lake Superior Regional Judges Award
Unread 06-02-2012, 12:42
FRC #1546
Thank you! Our programmers say that the LabView file or a screenshot of the target recognition code would be extremely helpful.
