Go to Post it's much easier to build safety in to a system than to add it on a Thursday at a regional. - dtengineering [more]
Unread 02-02-2012, 00:12
kully kekaula kully kekaula is offline
FRC #3880
kully kekaula is an unknown quantity at this point
Reducing Maximum Drive Speed Through Drive VI
I'm a first year programmer so I might have a lot of wrong ideas and false concepts of how to execute this but please bear with me
So my team wants to implement two individual drive systems: One to use on the bridge in which the bot's maximum speed is reduced to 1/3 the maximum speed for easier control, and another which is used normally on the field that will be run at full speed. The reason why I need two individual drive systems is that on the field we want to use a holonomic drive system for control, but on the bridge we want to use a tank drive, with the tank drive driving at 1/3 speed. We're planning on using an Xbox controller for the holonomic drive, one joystick for forward/backward and turning, and another for strafes. For the tank drive, we want to use a joystick that will be forward/backward and turning constituting the tank drive.
Now this leads me to two questions. How might I reduce the maximum speed of the drive systems in only ONE of the drive systems and will both drive systems work cooperatively if executed within the same teleop.vi?
Thanks for any help!
Unread 02-02-2012, 00:57
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Reducing Maximum Drive Speed Through Drive VI
To reduce the speed to 1/3 power, simply take the joystick axis and divide it by .66. this will scale the joystick to only output a third of its normal power. For the 2 drive systems, i would assign a joystick button to where, when held down, would change a case statement to use the tank drive code, and when it is released, use the normal holonomic code.
I'm right 90% of the time, so why worry about the other 3%?
Unread 03-02-2012, 21:38
FRC #3880
How exactly would something like that look? I currently have it where, in teleop, it opens the joystick and unbundles the buttons that control the case statement. Inside the case statement would be the normal teleop code for a drive system, including getting the motors and joystick and connecting them to the tank drive vi. Would something like that work? Thanks
Unread 03-02-2012, 21:39
Take a second closer look at that sentence.
Unread 03-02-2012, 22:09
FRC #3880
Im sorry, I should've clarified. I've gotten the reduction of speed to work but now I am confused as how to execute the two different drive systems.
Unread 03-02-2012, 23:44
Cecil's Avatar
AKA: Alex Hummel
Oh wow.. I need to go back to math class.. I'm sorry.. multiply it by .33…… -insert blushing emoticon here-
Unread 03-02-2012, 23:46
Cecil's Avatar
AKA: Alex Hummel
You don't necessarily have to put the entire thing inside that case statement. Call the motor refnum and joystick refnums outside, and have one side that passes straight into the tank drive for one side (so there is only the tank drive vi in the statement), and on the other side, have the same thing, only with your math statement too to scale it down.
Unread 04-02-2012, 01:31
FRC #3880
Okay, thank you very much Cecil! And no worries, I figured out what you meant by divide .66. I just substituted it for dividing by 3.
