UCPP Error
Hi, I'm having some problems with the ucpp project. I'm running arch linux, with wine version 1.3.35 and no programs installed into it except for whatever ucpp did. Here's what I did:
I downloaded the zip file from https://github.com/nikitakit/ucpp, unzipped it, then moved it to /home/adam I added /home/adam/ucpp/ucpp to my path, installed wine and wine_gecko (using pacman), then went to the directory where my c++ project is. There are three header files, two with constants and one is the header file for main, and main.cpp; and two directories with other classes. I typed: Code:
$ ucpp setup -t 3238 $ ucpp configure Code:
#! /usr/bin/env python2 I ran Code:
$ make Code:
building 2011-12-19-0_partialImage/Debug/2011-12-19-0_partialImage.o building 2011-12-19-0/Debug/2011-12-19-0.out wine: Unhandled page fault on read access to 0x6e795373 at address 0x7bc48b8b (thread 0023), starting debugger... Unhandled exception: page fault on read access to 0x6e795373 in 32-bit code (0x7bc48b8b). Register dump: CS:0073 SS:007b DS:007b ES:007b FS:0033 GS:003b EIP:7bc48b8b ESP:0067fc10 EBP:0067fc58 EFLAGS:00010202( R- -- I - - - ) EAX:00000f10 EBX:7bcb6ff4 ECX:00000000 EDX:00116c80 ESI:6e795373 EDI:00110014 Stack dump: 0x0067fc10: 00000200 00000370 7bc48891 7bc485ce 0x0067fc20: 00000004 7edebc40 0067fc48 7bc37321 0x0067fc30: 00000f0a 00000f10 0067fc98 00000f10 0x0067fc40: 00110060 7edec620 0067fc68 7bcb6ff4 0x0067fc50: 00110000 00000002 0067fcb8 7bc4923e 0x0067fc60: 00116c80 7ede3ff4 0067fc98 7ed92c53 Backtrace: =>0 0x7bc48b8b in ntdll (+0x38b8b) (0x0067fc58) 1 0x7bc4923e RtlFreeHeap+0x7d() in ntdll (0x0067fcb8) 2 0x7ed8e926 MSVCRT_free+0x25() in msvcrt (0x0067fcd8) 3 0x00455eba in nmppc (+0x55eb9) (0x0067fcf8) 4 0x0040b5d5 in nmppc (+0xb5d4) (0x0067fd08) 5 0x00409505 in nmppc (+0x9504) (0x0067fd18) 6 0x00409760 in nmppc (+0x975f) (0x0067fd78) 7 0x00402def in nmppc (+0x2dee) (0x0067fde8) 8 0x0040339e in nmppc (+0x339d) (0x0067fe28) 9 0x004011e7 in nmppc (+0x11e6) (0x0067fe60) 10 0x00401238 in nmppc (+0x1237) (0x0067fe70) 11 0x7b859b1c call_process_entry+0xb() in kernel32 (0x0067fe88) 12 0x7b85adaf in kernel32 (+0x4adae) (0x0067fec8) 13 0x7bc74550 call_thread_func_wrapper+0xb() in ntdll (0x0067fed8) 14 0x7bc7735d call_thread_func+0x7c() in ntdll (0x0067ffa8) 15 0x7bc7452e RtlRaiseException+0x21() in ntdll (0x0067ffc8) 16 0x7bc4bc5e call_dll_entry_point+0x33d() in ntdll (0x0067ffe8) 17 0xb76e99bd wine_call_on_stack+0x1c() in libwine.so.1 (0x00000000) 0x7bc48b8b: movl 0x0(%esi),%edx Modules: Module Address Debug info Name (16 modules) PE 400000- 47a000 Export nmppc ELF 7b800000-7b9c4000 Dwarf kernel32<elf> \-PE 7b810000-7b9c4000 \ kernel32 ELF 7bc00000-7bcd3000 Dwarf ntdll<elf> \-PE 7bc10000-7bcd3000 \ ntdll ELF 7bf00000-7bf04000 Deferred <wine-loader> ELF 7ed52000-7eded000 Dwarf msvcrt<elf> \-PE 7ed70000-7eded000 \ msvcrt ELF 7efb2000-7efbf000 Deferred libnss_files.so.2 ELF 7efbf000-7efe9000 Deferred libm.so.6 ELF b752c000-b7531000 Deferred libdl.so.2 ELF b7531000-b76ae000 Deferred libc.so.6 ELF b76ae000-b76c9000 Deferred libpthread.so.0 ELF b76e0000-b7823000 Dwarf libwine.so.1 ELF b7824000-b7845000 Deferred ld-linux.so.2 ELF b7845000-b7846000 Deferred [vdso].so Threads: process tid prio (all id:s are in hex) 0000000e services.exe 0000001e 0 0000001d 0 00000019 0 00000017 0 00000015 0 00000010 0 0000000f 0 00000012 winedevice.exe 00000018 0 00000014 0 00000013 0 0000001a plugplay.exe 0000001f 0 0000001c 0 0000001b 0 00000020 explorer.exe 00000021 0 00000026 licproxy.exe 00000027 0 0000000b (D) Z:\home\adam\.ucpp\gccdist\WindRiver\gnu\3.4.4-vxworks-6.3\x86-win32\bin\nmppc.exe 00000023 0 <== Backtrace: =>0 0x7bc48b8b in ntdll (+0x38b8b) (0x0067fc58) 1 0x7bc4923e RtlFreeHeap+0x7d() in ntdll (0x0067fcb8) 2 0x7ed8e926 MSVCRT_free+0x25() in msvcrt (0x0067fcd8) 3 0x00455eba in nmppc (+0x55eb9) (0x0067fcf8) 4 0x0040b5d5 in nmppc (+0xb5d4) (0x0067fd08) 5 0x00409505 in nmppc (+0x9504) (0x0067fd18) 6 0x00409760 in nmppc (+0x975f) (0x0067fd78) 7 0x00402def in nmppc (+0x2dee) (0x0067fde8) 8 0x0040339e in nmppc (+0x339d) (0x0067fe28) 9 0x004011e7 in nmppc (+0x11e6) (0x0067fe60) 10 0x00401238 in nmppc (+0x1237) (0x0067fe70) 11 0x7b859b1c call_process_entry+0xb() in kernel32 (0x0067fe88) 12 0x7b85adaf in kernel32 (+0x4adae) (0x0067fec8) 13 0x7bc74550 call_thread_func_wrapper+0xb() in ntdll (0x0067fed8) 14 0x7bc7735d call_thread_func+0x7c() in ntdll (0x0067ffa8) 15 0x7bc7452e RtlRaiseException+0x21() in ntdll (0x0067ffc8) 16 0x7bc4bc5e call_dll_entry_point+0x33d() in ntdll (0x0067ffe8) 17 0xb76e99bd wine_call_on_stack+0x1c() in libwine.so.1 (0x00000000) make: built targets of /home/adam/team3238/2011robotcode/cpp/2011-12-19-0/PPC603gnu Code:
err:ntdll:RtlDeleteResource Deleting active MRSW lock (0x111f64), expect failure Since I don't have a cRIO handy, I'm not sure if this is actually affecting the outputted code or the deploy function. Hopefully I can get an answer to what the problem is or help the developer fix something. |
Re: UCPP Error
Can you post the code that you were building?
My guess is that Wine had a regression. Can you try another version of Wine? Keep this thread up to date, and we/I will do our best to help. If you are having problems, then it isn't perfect yet. |
Re: UCPP Error
Here's the code. It has a few warnings, sorry about that. I'll see if I can downgrade, but it would be pretty tricky.
Re: UCPP Error
Let me start with the doozey. Not a make export, and defiantly not a wine expert.
Now here is what I think Quote:
Re: UCPP Error
ucpp installs the compiler suite for Windriver automatically from a set of tools that NI puts out for free on their website. (Don't have the link handy, but you can read it from the source.) This smells like a wine regression to me, or a bug in nmppc triggered by something odd happening in wine.
It may take a day or so for me to poke at it, but I'll try my best to get back to you. (PM me or something if I forget...) |
Re: UCPP Error
Just thought that it may be useful to try compiling my code on the "real" windriver and comparing it to what compiled on my machine and see if they're the same file.
EDIT: Downgrading wine to 1.3.8 seemed to have fixed the problem. I assume you'll want to submit a bug report to the wine developers Last edited by WizenedEE : 20-12-2011 at 03:16. Reason: Added info |
#7
Re: UCPP Error
Glad to hear it!
#8
Re: UCPP Error
The regression still exists in wine 1.4
#9
Re: UCPP Error
With the lastest version of ucpp and wine, everything compiles successfully and I get no errors (and I don't have to modify the files I said in the last post). I have not tried downloading code to a robot, though.
Thanks for all your hard work! It's great to even check for syntax errors without getting errors about "CANJaguar is not a type" |
