Go to Post I predict someone has to eat a hat! :D - FiMFanatic [more]
Unread 30-01-2012, 20:20
arrou.keys arrou.keys is offline
None #1100
arrou.keys is on a distinguished road
Exclamation How to fix pins onto a 3-pin PWM cable?
Can someone tell (or show) how to fix pins onto a 3-pin PWM cable? It's the thin cable that's red, black, and white, with a black piece with 3 small pins on the end (used for VEX Robotics).
We have only one side with pins, but need the other side to have pins, as well, but we don't know how to put the pins in.
Do you have to take the end-piece apart, or are you supposed to somehow force the pins in?
Thanks!
Unread 30-01-2012, 20:34
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: How to fix pins onto a 3-pin PWM cable?
Watch the video here:
http://www.hansenhobbies.com/
Unread 30-01-2012, 20:53
Zembas's Avatar
Zembas Zembas is offline
AKA: Jonathan Oishi
FRC #0359 (The Hawaiian Kids)
Zembas is on a distinguished road
You'll need to crimp on the male connectors and rehouse them, otherwise you'd need to buy the cable that way.
You can purchase a kit for work on PWM from Hansen Hobbies. (See above post)
Unread 30-01-2012, 21:36
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
in a pinch one could use thin solid wire... it is a kludge but it works.
Unread 30-01-2012, 21:40
DonRotolo's Avatar
Back to humble
FRC #0832
If time is short, you can cut another cable with a male end and solder the wires together in the middle.
Unread 04-02-2012, 10:37
None #1100
I just nudged the broken pin out with a Wago tool, solder a new one onto the wire, and pushed it back in!
Thanks for the replies!
Unread 05-02-2012, 12:51
Nathan4567a's Avatar
Nathan4567a Nathan4567a is offline
Circuit Master
AKA: Nathan Lerner
FRC #2587 (Discobots)
Nathan4567a will become famous soon enoughNathan4567a will become famous soon enough
Go to your local electronics store and buy a strip of header pins. Be sure to buy the kind with the plastic spacer in the center of the pins. It should look like the one in the attached file. You don't need to worry about crimping. After you buy the pins, simply stick them in the female side of the connector and you are done. It is very easy and passes the current perfectly.
