Go to Post there is no mechanics Barbie. - Iain McLeod [more]
Unread 24-01-2012, 18:19
Pirate programe's Avatar
Pirate programe Pirate programe is offline
FRC #0354
Pirate programe is an unknown quantity at this point
Using Target Distance to Move Robot
Since we managed to get the Rectangular Target Processing VI functioning, we're now trying to use the Distance information to move the robot.
The problem is, with the teleop code used in the attachment, the robot doesn't move at all. I can't imagine that there's anything wrong with the drivetrain, since the robot's been driving a lot before we modified the code.
What could be the problem?
Unread 24-01-2012, 18:30
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Using Target Distance to Move Robot
At first glance, I would say that .1 is a fairly low drive value and may not be enough to move a robot. Have you tried it on blocks to see it the wheels turn?
I also think you will find you are introducing a turn with those values. Arcade drive uses X and Y input. X will cause the robot to turn.
Lastly, the vi is using the following logic:
If distance is greater than 6, drive at .1 and .1.
Is that what you are thinking as well?
Unread 24-01-2012, 18:34
FRC #0354
No, I haven't. I think I might just turn the values up...
did this get cut off?
I was thinking more "Drive at .1 and .1 until Distance is less than 6" , but I think your formulation applies too.
Unread 24-01-2012, 18:42
billbo911's Avatar
Ooops, I dropped the period at the end of that line, I've corrected it now.
Your logic and code are correct. It should operate as you expect.
Unread 26-01-2012, 16:23
FRC #0354
So, the code logic is correct, but the robot won't move anyway? That doesn't make much sense.
By any chance, could this have something to with the "The loop that contains RobotDrive is not running fast enough" errors we're getting?
If not, what else could it be?
Unread 26-01-2012, 17:01
jcbc's Avatar
jcbc jcbc is offline
AKA: Julie
jcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the rough
We have found that the Rectangular Target Processing VI takes up too much of the cRIO's memory and processing to run our drive code at the same time. We are looking into running the targeting code off of the cRIO, but we're still in the early stages.
Unread 26-01-2012, 20:15
Can you be more specific? Is it RAM or CPU? Processing on the laptop is certainly an option, and discussed to a degree in the Example and white paper. If you drop the framerate, and perhaps even lower the priority of the processing, you should be able to control how much CPU is used.
Greg McKaskle
Unread 31-01-2012, 18:24
FRC #0354
This is weird.
I can confirm that the code logic is correct already, since when I wire the Joystick inputs instead of constants, the robot can move when the condition is met.
Could there be a problem with the input values I'm using? I noticed through probing wires that the values the joystick gives aren't scaled from -1 to 1...
EDIT: Actually, no, I was reading the numbers wrong. They should be the same as the ones the joystick uses...
Unread 04-02-2012, 13:04
FRC #0354
Greg McKaskle
After fiddling around with the targeting code we got running, I think it'd be best if we did this. What sort of modifications would we have to make to the Rectangular Target Processing code to do this, do you think?
The Send Axis Camera Signal Directly to Dashboard says the Read MJPG vi is what's used, but I'm not sure if that translates to this situation?
Unread 04-02-2012, 13:19
The example project has code in the computer target section for running on a laptop, and code in the cRIO section for running on the cRIO.
The primary task would be to integrate the LV loop into the dashboard and to get the data back to the robot -- I'd recommend using UDP.
Greg Mckaskle
Unread 04-02-2012, 14:20
FRC #0354
Greg Mckaskle
...he says, as though this were the simplest thing :|
Another potential hiccup: whenever something obstructs the camera view, or even when the camera is simply stationary, the index of a particular target in the Target Info array changes. That could be a problem if we're trying to narrow on a particular target. My mentor says we should be able to make the code remember certain position coordinates, and assign them to a specific index, so that if a target is at index 1 and its postion is (-0.5, 0.5), for argument's sake, if we obstruct the camera view and then unobstruct it the target should still be reassigned to index 1. Any idea how to implement this?
Unread 04-02-2012, 17:43
The dashboard code already has independent loops that do UDP. For example, the loop that reads the Kinect Server data is towards the top of the Dashboard diagram. The important part is shown below.
It reads from port 1166 about once a second, or whenever data arrives. It reads at most 1018 bytes as a string, and then interprets it as the agreed datatype. In the situation we are considering, a similar loop would be placed on your robot and run in parallel with everything else -- I'd suggest doing it in Periodic Tasks.
The second image shows the code that needs to run on the dashboard to send the data. You need to change team and you need to make the data constant be your own data either formatted or flattened to a string. The final piece is to identify the UDP port to use and use it for both the read and write.
As for the index problem, I'm pretty sure that is currently based on the particle size. I'd probably try to sort them by location and label them as top, left, right, and bottom. You could then store them in a cluster or an array with a unique cell for top, left, right, and bottom. You should be able to identify them with any sorts of simple sort techniques.
Greg McKaskle
Name:	Screen Shot 2012-02-04 at 3.57.43 PM.png
ID:	11707  Click image for larger version
Name:	Screen Shot 2012-02-04 at 4.10.18 PM.png
Unread 06-02-2012, 15:44
FRC #0354
So then, would we have to run the Vision Processing code on the dashboard, write to the robot using UDP, then have the robot read the UDP packets using code in the Periodic Tasks VI?
never mind that, wasn't reading correctly.
I guess the challenge is finding out how to convert the image to a string (the Get Image Data String VI requires a CameraDevRef input).
Unread 06-02-2012, 18:19
Provided the camera is connected to the dlink, you don't need the cRIO to do anything with the image.
The dashboard reads the image directly from the camera.
The dashboard processes it.
The dashboard sends any target info to the robot via UDP string.
The robot reads the TDP string and updates setpoints which ultimately move the robot.
You don't have to do it this way, but if you want to use the laptop to do the processing, to allow the cRIO CPU to do other things, this is the way I'd approach it.
Greg McKaskle
Unread 06-02-2012, 18:31
FRC #0354
Greg McKaskle
Would the Dashboard really be able to have the entire Rectangular Target Processing code in it?
also it'd be nice if you could direct your attention here, if it's not too much trouble?
