Go to Post The culture has shifted, people. You can act shocked and complain, and likely lose the attention of the students you want to reach through FRC and other activities, or you can shift with it, and make FRC relatable and relevant to a bunch of good kids with foul mouths. - mrnoble [more]
Unread 04-02-2012, 11:08
codalafin codalafin is offline
FRC #1095
codalafin is an unknown quantity at this point
Switch Latching
I want to use a physical switch to act how a boolean control does. Specifically I need the ability to use "latch when released", activating a case structure when the switch goes from True to False. I have no idea where to begin with doing this, but I've opened the digital input, set the channel it runs on, set it under a variable name, and gotten its true-false value. Where do I work from there?
Also, if the answer would be in LabView help, I'm sorry but for some stupid reason the help doesn't load on this computer. I waited 15 minutes for the "Boolean Controls" page to load hoping that might have an answer and it never did.
Unread 04-02-2012, 13:02
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: Switch Latching
The way I do it is to use a global variable.
I Use a case structure that is asking for the boolean and every time it turns true the value of the boolean is inverted.
Now in the picture I have it in teleoperated which causes some problems because you can't instantly press and release the button. So it cycles through true and false very quickly and I recommend some way of knowing the value.
Follow the Button Toggle Action example HERE
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 04-02-2012, 13:26
FRC #1095
Re: Switch Latching
I don't think a toggle button will solve my issue. That would save the state until I pressed it again, which is most certainly not what I want.
Pretty much, in waveform description, I want the case structure to activate when the digital wave goes from 1 to 0.
I also can't use what that picture shows, since the variable will keep changing every moment the switch is pressed.
Unread 04-02-2012, 13:43
FRC #0379
Re: Switch Latching
Okay I see what you want now. You want the action to only change when it goes from 1 to 0 and not when it goes from 0 to 1.
Unread 04-02-2012, 14:40
FRC #1095
Re: Switch Latching
I've tried multiple possible options, including storing a variable, but I can't figure out a way that works.
Unread 04-02-2012, 15:41
FRC #1095
Re: Switch Latching
Okay so I may have found what I need, can't test it at the moment but http://team358.org/files/programming...tonRelease.jpg that node + less than system should work fine. genius design
Unread 04-02-2012, 18:45
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Switch Latching
Maybe this is solved, but what if you stop checking the condition of the switch after it has activated the first time?
Pseudocode:
If SwitchedOn is ON, jump to move_along
.Check switch
.If switch is 1, set SwitchedOn to ON
move_along
...the rest of the code...
Unread 04-02-2012, 20:48
Re: Switch Latching
That's exactly what you want. I've made teeny little SubVIs that just take a boolean input and do the feedback node/comparison step, calling them "RisingEdge" and "FallingEdge". Their icons are very small.
