Go to Post I got Vista with mine. It's like getting moldy fruitcake for Christmas. - Koko Ed [more]
Unread 29-01-2012, 12:47
gabrielc97's Avatar
gabrielc97 gabrielc97 is offline
AKA: Gabriel
FRC #4029 (Spartan Bots)
gabrielc97 is an unknown quantity at this point
Question How to Invert the motors?/ Programming joystick Buttons? LabVIEW
We cant figure out why our robot moves left when you move the joystick right, and the other way around. we are using LabVIEW. My team could also use help programming the buttons on a logitech attack 3.
Any help is appreciated! thanks.
Gabriel
Unread 29-01-2012, 14:55
Re: How to Invert the motors?/ Programming joystick Buttons? LabVIEW
If you are using arcade drive and your robot forward and reverse is correct but left and right is reversed, there are two problems that both need to be corrected to fix the problem.
First, your left motor PWM and right motor PWM are reversed. Swap PWM 1 and 2.
Second, your, the polarity of your motors are reversed. You can change the Robot Drive inverted booleans in begin.
Unread 29-01-2012, 14:57
SeleneCast00's Avatar
SeleneCast00 SeleneCast00 is offline
AKA: Selene Castaņeda
FRC #4029 (SpartanBots)
SeleneCast00 is an unknown quantity at this point
(ADDITIONAL DETAILS) We just noticed that whenever we push the joystick slighty forward or back, the robot starts twisting slighty as it advances more than two yards. Similar to the way that some shopping carts tend to do when you push them away and they slowly start moving to the side rather than going straight. Could this be a problem fixed by changing some parameters related to speed? One side is always a bit faster.
Thanks! <(^_^<)
Unread 29-01-2012, 16:30
gabrielc97's Avatar
AKA: Gabriel
Thanks, we are tried to change the PWM cables on the robot, and the PWM in the actual program. We found out that the robot isn't receiving the edited program.
Gabriel
Unread 29-01-2012, 18:30
Only change one of them. Make the wires match the program. If you swap both the wires and the program definitions, it will have the same effect as doing neither.
What do you mean? How are you trying to send the program to the robot, what do you expect to happen, and what is happening instead?
Unread 04-02-2012, 16:07
haljarrett haljarrett is offline
FRC #4189 (Jackson-Barrow Robotics)
haljarrett is an unknown quantity at this point
I had a similar problem loading code. In LabView, there are 2 ways to load and run your code. From robotmain.vi, you can click the run button to send your code to your robot in interpreted/connected mode(you run connected to your front panel actively). As soon as you lose power, though, that running code is dropped. This mode is great for debugging. To make your code stay on the cRIO, you must build a Real-Time application(.rtexe) out of your code. To do this, expand the tab that says "Build Specifications" under "RT CompactRIO Target(10.xx.yy.2)". There should be node that says "FRC Robot Boot-up Deployment" Right click and select "build". It will take several minutes to compile the code. When it is done, right click and select deploy. When that is done, either reboot your cRIO or cycle the power. Your code will now be persistent.
Unread 06-02-2012, 13:33
mayingjunlang95 mayingjunlang95 is offline
FRC #0540
mayingjunlang95 is an unknown quantity at this point
Just put multiply by -1 for the set output for the motor should help
Unread 21-01-2016, 11:52
spokengear spokengear is offline
FRC #4656
spokengear is an unknown quantity at this point
We are having a problem with arcade drive in reverse only. Move the joystick to the left and back, the robot goes reverse and to the right. In forward mode it turns correctly. Any help would be greatly appreciated.
Unread 21-01-2016, 12:38
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
First:
Make sure that your PWM numbers in Begin match the numbers on your bot.
Second:
Make sure to reverse (using the true/false option on the top and bottom of the vi) only one side of the drive motors: either all the motors on the left, or all the motors on the right. But not both sides.
I kind of know programming
Unread 22-01-2016, 08:46
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
If the problem still persist, please post screen shots of begin and teleop and pictures of the wiring.
You also asked about programming with the buttons. A few things to keep in mind:
The trigger on the Attack 3 is button 1 (the others are labeled)
When you index the array of button values to from the joystick_get_values vi (use Index Array under the array palette), the index is 0 based and the buttons are 1 based, so subtract 1 from the desired button number to get the required index.
Buttons are true the entire time they are pressed, so if desiring for a button to trigger an action (as opposed to the action goes while the button is pressed) consider using the edge detector from Breakaway's memory library (http://frclabviwtutorials.com/memory...y/#description).
Unread 22-01-2016, 10:20
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
The other problem you may be having is the +- assumption of the joystick inputs. Check the joystick axes inputs on the dashboard as you move the joystick. You may be assuming left/right has a certain positive/negative setup on the joystick axis, and it is actually reversed.
Unread 22-01-2016, 18:15
RockSolid4656 RockSolid4656 is offline
FRC #4656
RockSolid4656 is an unknown quantity at this point
Our robot is doing the same thing, and we have already attempted to invert the motors and switch the PWMs around. We have no idea what to do, could you possibly help us?
Unread 22-01-2016, 22:15
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
General trouble shooting: Have only one motor powered at a time. Verify it is moving in the correct direction when you command the robot forward/back/left/right. If it doesn't, you have it hooked up wrong in either code on wiring. Repeat this for each motor.
