Go to Post You dont get paid based on your IQ, or how many things you have memorized, or what you can invent on your feet. You get paid for results. - KenWittlief [more]
Unread 04-02-2012, 16:36
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Spike Red Light?
I have one of the Innovation First Spikes hooked up to the PD board. Nothing else is connected to the spike, nothing to the M+ and M- and nothing to the pwm port.
When I turn on the robot, the spike has a solid red light.
According to the User Guide for the spike, red means reverse. However, if I take a multimeter to the M+ and M- terminals, i get 0V
When I take the multimeter to the 12V and GND terminals, I get 12V so the spike is definitely getting power. And definitely no chance of reverse polarity because 12V terminal is connected to the red on the PDB and GND is connected to black on the PDB.
Also, fuse looks intact.
I am really puzzled by this and I hope you guys can help.
Unread 04-02-2012, 16:50
Re: Spike Red Light?
I seem to remember getting a solid red light with no PWM cable attached, but I can't say for sure. See if the light goes out when you plug the PWM cable in to the Relay port on the Digital Sidecar.
Unread 04-02-2012, 16:58
Nope, they dont change color.
Unread 04-02-2012, 17:02
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
Have you tired a different spike and got the same problems?
Prototype, Prototype, Prototype
Unread 04-02-2012, 17:53
we have 3 spikes and they all do the same thing.
2 are innovation first, one is the vex pro one.
Is it maybe because we aren't sending it a signal?
The B on the spike PWM port is where the GND of the PWM cable goes right?
Unread 04-02-2012, 18:02
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
When the spike outputs +12V, the LED will be green. When it outputs -12V, the LED will be red. It will be yellow when it outputs 0V.
But IIRC, the light is red when it doesn't have signal.
Unread 04-02-2012, 18:20
DonRotolo's Avatar
Back to humble
FRC #0832
Note that Spike Relays do NOT get connected to PWM outputs on the Digital Sidecar; instead they must be connected to "Relay" outputs. And yes, B indicates Black (Ground)
Also, actually remove the fuse and check it, or measure its continuity.
Unread 04-02-2012, 18:57
dakaufma dakaufma is offline
AKA: David Kaufman
FRC #0449 (Blair Robot Project)
dakaufma is an unknown quantity at this point
In my experience the "yellow" for no signal looks very red. If it turns green when you set it to forward and red (generally a slightly different red, although I don't think I could say which is which out of context) when you set it to reverse then you're fine.
It sounds like the spike is operating correctly.
Unread 04-02-2012, 19:37
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Actually, according to the user guide on the IFI website, the OFF state with both M+ & M- at ground is indicated by the LED glowing orange.
Is the LED really red or does it look somewhat orange?
Unread 04-02-2012, 19:42
I'd vote that the neutral color of the signal light just happens to appear to be a shade of orange/red.
We have debates about what color the real neutral shade is all the time.
The fuse is also good if you have a light. It goes out altogether if there's no fuse. The Spike circuits are protected by the fuse.
Unread 04-02-2012, 21:05
I guess you could say it is orange.
Unread 05-02-2012, 12:45
nitneylion452's Avatar
AKA: Joe Lee
Then it's definitely that you have a lack of signal. If when you connect a motor, or whatever your desired application is, and apply a signal, you should see green/red lights. Seems like you're okay.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 20-02-2012, 13:52
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
I know for our team we have one or two spikes whose "orange" is actually a bit more red than I would really like. Other than that, they work fine. Try using them, they should still work perfectly.
Unread 20-02-2012, 23:14
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Spikes are a very random moor controller. The fuse can be intact, the PWM can be plugged into the correct relay slot, and a light may appear, but sometimes it just refuses to work. Our team has a LOT of OLD spikes and a few, that were tested, work so far without any indication. I know this because tested the same spike and compared I with the new VEX spike by changing the Relay PWMs to the new spike and got a signal. So if the problem persists, just keep testing to your heart's content.
Hope his helped and Happy Competitions!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 25-02-2012, 21:10
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Light is usually orange when powered up. We had a red light on one of our spikes when we powered up, pulled out the pwm to find it melted. Yeah, it smelled bad and was toast. Don't know for sure if the red light was indicating a fault, but I'd put a small amount of money on it.
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
