Go to Post Wow, 3 people able to draw their designs using text in a script processor program. I guess I wasted my time learning all that CAD software - Gary Dillard [more]
Unread 04-02-2012, 16:40
moc601 moc601 is offline
FRC #0601 (Baybots)
moc601 is an unknown quantity at this point
FPGA incorrect version or revision
I've programmed the simple motor control example on the driver station and another Win7 laptop, they both fail to run the drive motor in my workbench setup.
Using a probe on the "motor open" "Motor controller device ref" wire I get this message on both systems.
I'm unable to locate the FPGA version, does anyone know where I might find it?
Loaded FPGA has incorrect version or revision.
Library expecting Version 2012, Revision 1.6.4.
FPGA_SystemOpen.vi>>FPGA_SystemAsync VI Agent.vi
<time>06:28:06 02/05/2012<unique#>614
Unread 04-02-2012, 16:47
Re: FPGA incorrect version or revision
Have you reimaged your cRIO with the 2012 image?
Unread 04-02-2012, 16:53
FRC #0601 (Baybots)
Yes, I've been using the imaging tool that you pointer me to earlier today.
All the slots are green and the image displayed in the window is FRC_2012_v43.zip which I believe is the desired V43.
Unread 04-02-2012, 16:59
FRC #0601 (Baybots)
Oops I stand corrected, the version in the upper window on the discovery line indicates the FRC_2011_V28.
I'm formatting and installing V43 now.
Unread 04-02-2012, 17:15
FRC #0601 (Baybots)
All is now well, I was reading the wrong window.
