Go to Post Basically: engineering is fun. - Mike [more]
Unread 04-02-2012, 10:49
arrou.keys arrou.keys is offline
None #1100
arrou.keys is on a distinguished road
Do we need to use circuit breakers with Window Motors?
If so, how many amps? 20, 30, or 40?
Do we need a Spike Relay, too?
Unread 04-02-2012, 11:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Do we need to use circuit breakers with Window Motors?
You need either a Spike or a speed controller (Jaguar, Victor, etc). The breaker size should depend on the size of wire among other things, but 20 amps is what we've always used with window motors.
Unread 04-02-2012, 11:03
None #1100
Thanks!
Unread 04-02-2012, 17:30
I'm curious. If you didn't use a circuit breaker, how would you be providing power to the motor?
Unread 04-02-2012, 19:14
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The stall current is actually right around 20 amps. I think the right is slightly below and the left is slightly above. The left one is uses slightly more current because it is slightly more robust as the driver's side window is used more than the passenger's side window in most cars.
