Go to Post Unsure if I'll get it to work, but that's no reason to not try. - DonRotolo [more]
View Poll Results: What weight is your team shooting for?
Will go out of way and add material to make the robot 120 lbs. 46 35.94%
Will shoot for 120 lbs, but will not necessarily make it. 26 20.31%
Going for the lightest robot possible. 25 19.53%
Not shooting for any specific weight. 26 20.31%
Other 5 3.91%
Voters: 128. You may not vote on this poll
Unread 03-02-2012, 19:39
Andrew Lawrence
Posts: n/a
Re: Robot Weight
We're aiming for 120. That way since most teams are around that weight, it'll be easier to balance the bridge. Only thing now is to start drilling holes! Actually, we may come in a littl under this year. We'll then need to pack on extra stuff to get to 120!
Unread 03-02-2012, 20:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot Weight
We're aiming for 120 and on course for 130
Bare frame, pretty much complete with all the mounting brackets for everything, is 27 lbs.
Unread 04-02-2012, 17:47
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
Re: Robot Weight
We're at 118 lbs, but a few small components still need to be added. That's too bad, now we'll have to water jet our logo out of some parts of the robot.
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
Unread 04-02-2012, 17:59
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Robot Weight
Originally Posted by Polaris395 View Post
I think it will be pretty safe to assume that everyone is +/- 10 pounds from 110lbs.
This is a dangerous assumption to make, IMO. Last year, there were 'competitive' robots as light as 90lbs without bumpers and batteries. This year, I'd imagine that there will be a robot or two at each event that are well underweight.
Personally, we're shooting for as low of a weight as is reasonable with the intent of being able to ballast ourselves (method tbd) up to the weight that balances best with our partners, though some testing that teams have done may have proven that this might not be needed.
-Dustin Benedict
Unread 04-02-2012, 18:03
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Robot Weight
Our drive alone is 86 lb... I am worried...
Unread 04-02-2012, 20:02
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Robot Weight
That is actually something to be worried about. Ours was ~65 last year, and we had dual layers of T-Slot and tubing, along with 8 idlers and tank treads. This year, we're down to ~50, after beginning the transition to sheet metal construction by water-jetting our side panels out of 3/16th plate. What are you guys doing that requires 86 lbs? Unless its two drive trains for going X and Y, you might want to get out the drill.
Unread 04-02-2012, 21:42
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Robot Weight
I warned everyone about it, but they went with the 14 inch wheels. In order to support those 14 inch wheels, one of our mentors had to make a brace for the sprocket. In order to chain them up, 4 big metal plates are required for the gearboxes. It is slow, sluggish and cumbersome. It was designed to to over the bump, but it flips over.
Unread 04-02-2012, 22:43
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: Robot Weight
I second this, our 2012 robot was 78 lbs with the drive-train, and while making weight wasn't all that hard It was very limiting to us and caused a lot of stress. I would try to cut weight wherever you can, learning from last year we managed to got our 2012 robot down to 51 Lbs without any worries about structural strength. If you need more than 30LBS for a frame, you are doing something wrong.
Unread 04-02-2012, 22:50
Andrew Lawrence
Posts: n/a
Re: Robot Weight
Our drive this year along with our ball sucker and motors are about 48 pounds, and our ball elevator and shooter are about 50, leaving us about 30 pounds for our bridge manipulator.
Unread 04-02-2012, 23:34
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: Robot Weight
We weighed in at 97.5lbs tonight with mostly everything. We'll probably be at least 110 before everything is on then we'll slap a 9.4lbs steel bellypan on the bottom. But seriously, I'm pulling for it..
In any case, we'll be 119.9lbs like every year by the time we bag it.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 05-02-2012, 00:02
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Robot Weight
Our team typically doesn't try to make it's robot exactly 120 pounds--it just sometimes ends up that way. However, when the robot it underweight (ie more than a few pounds below 120) we don't go out of our way to add weight.
Remember, although it is true that a heavier robot is harder to push around, a lighter robot has a number of advantages. A lighter robot can accelerate and travel a lot faster, is easier to turn, and is more maneuverable. I've heard that 254 keeps their robot at 90lbs for the extra performance.
Edit: Thats 120, not 1220 lbs. Thanks SuperNerd
Unread 05-02-2012, 00:09
Andrew Lawrence
Posts: n/a
Re: Robot Weight
Originally Posted by DampRobot View Post
Our team typically doesn't try to make it's robot exactly 120 pounds--it just sometimes ends up that way. However, when the robot it underweight (ie more than a few pounds below 1220) we don't go out of our way to add weight.
Well I hope your robot us under 1220! While a light robot has its obvious advantages, heavier robot's advantages are often overlooked. The huge one (pushing power, and harder to push) are not the only advantages of being exactly 120 pounds. A great example is this year. If both robots are 120 pounds (most of them will be), then it'll be much easier to balance on the bridge verses a 120 pound robot and a 90 pound robot (Not saying 254 shouldn't pick us if they're going for 90 pounds. We'd work great together in the elimination rounds! )
Unread 05-02-2012, 00:19
pfreivald's Avatar
AKA: Patrick Freivald
Re: Robot Weight
Our drive train, including electronics and pneumatics, is ~80 lbs. Piling on every component we think we're going to need we get to 107 lbs. Assuming some additional support struts and little wibblybits we haven't made yet and some lexan side panels make up the rest of that weight, we're on target for 120 lbs, maybe a little less -- which we will make up for with ballast.
One goal for us is to keep our CG in the very, very center of the horizontal cross section of the robot and at or below the plane of the frame -- and it looks like that's going to happen!
On a side note, I don't buy that 90 lb robots are inherently faster than 120 lb robots. Depending on the drive train, acceleration can be torque-limited or traction-limited, speed depends on gearing, and turning ability depends on a whole lot more than weight.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 05-02-2012, 00:27
Wink Re: Robot Weight
Originally Posted by SuperNerd256 View Post
Our drive this year along with our ball sucker and motors are about 48 pounds, and our ball elevator and shooter are about 50, leaving us 30 pounds our bridge manipulator.
Just incase you end up messing yourself up on robot weight, I should point this out now.
Unread 05-02-2012, 00:34
Andrew Lawrence
Posts: n/a
Re: Robot Weight
lol. As for the math, 48 + 50 = 98. That means we have about 30 pounds for our bridge manipulator, though it won't weigh that much.
I put in the about to make it more accurate. 50 + 48 + 30 ≠ 120, but 50 + 48 + 30 ≈ 120
