Go to Post not national champ.....WORLD CHAMPION - Stephen Kowski [more]
Unread 04-02-2012, 18:26
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
CIM-SIM Noise
I was wondering what kind of noise levels other teams are getting out of their CIM-SIM gearboxes from AndyMark (http://www.andymark.com/product-p/am-0932.htm),
Ours is assembled and greased with 2 banebot 550's, and makes quite a racket when powered - borderline hearing protection required loud.
Thanks!
Unread 04-02-2012, 18:35
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: CIM-SIM Noise
Thanks!
2 things:
1> the screws that came with the cim-sim are too long for the 550s and will cause binding. you'll need to shorten them to avoid binding (at least we had to)
2> We've found that, while very good, the Andy Mark gearboxes require that you grease them, break them in for 1/2 hour, take them apart, clean them, and then rebuild and regrease them. if you don't you'll end up with menal filings within the gearbox and that will cause more torque loss and greater gearbox heating (and possibly more noise).
___________________
- Tennyson, Ulysses
Unread 04-02-2012, 18:42
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: CIM-SIM Noise
Our's is assembled with two FP 0673's and also makes pretty loud noise, despite being greased up. It seems to be a common thing.
Unread 04-02-2012, 20:49
cire's Avatar
AKA: Eric Diehr
Re: CIM-SIM Noise
Originally Posted by Daniel_LaFleur View Post
2 things:
Yes, we noticed the screw problem and fixed accordingly.
I think we will try running them in some more and rebuild. I am considering putting some lapping compound between the teeth to help wear them in.
Thanks for the ideas!
Unread 04-02-2012, 21:13
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: CIM-SIM Noise
This is great advice. We've been doing this with all of our AM boxes since the Toughbox was introduced in 2008. Usually, we'll assemble them, run them for a bit on a bench switching between forward and reverse periodically, crack them open and check to make sure everything plays well together. Usually we can hear a difference after just a few minutes of run time.
-Dustin Benedict
Unread 07-02-2012, 00:24
Andrew-StL's Avatar
Andrew-StL Andrew-StL is offline
FRC #2978 (Cavaliers)
Andrew-StL is an unknown quantity at this point
Re: CIM-SIM Noise
Our team received two additional Toughbox kits last week from AndyMark, built them up over the weekend, and then got to testing them this evening. When we tested them, we got a grinding noise in both of the new boxes. When we opened up both boxes that the team put together, we discovered that the short shaft in both were machined incorrectly. The length is correct, but the hex length is too long (longer than spec).
We took a picture of the new shaft, and an "old" shaft that we pulled out of a "good" Toughbox, and will be contacting AndyMark tomorrow. Guessing it is a bad batch of shafts. Will pass on what we find out from AndyMark.
