Go to Post Seeing a bunch of teams from Indiana and probably Michagin competing at the same time.... If I wanted to see that, I'd just go to the Championship in Atlanta. :yikes: - Barry Bonzack [more]
Unread 02-02-2012, 10:07
jman1783 jman1783 is offline
FRC #2900 (Mighty Penguins)
jman1783 is an unknown quantity at this point
Classmate ethernet port broken - fix?
Not sure how this happened, but the ethernet port on our Classmate is broken. The connection works if you hold the cable in, but the opposite of what typically happens seems to have happened - the tabs on the ethernet cable have nothing to grab onto in the Classmate, implying that somehow some kind of latch got busted.
Anyone have any experience with this, and know a good fix? Is this the kind of thing that would require us to replace the Classmate? I'm worried that programming will routinely lead to corrupt downloads to the cRIO, which is probably part of the reason we haven't been able to show that code is on the robot, despite what seems to be a successful deployment via Labview.
Thanks,
-Justin
"Just remember - whether you think you can or you think you can't, you're right." -Stewart Gilligan Griffin
Unread 02-02-2012, 10:15
sometimestommy's Avatar
sometimestommy sometimestommy is offline
Schrödinger's Assistant
AKA: Thomas Moll
FRC #1939 (Ku-Nig-Its)
sometimestommy is on a distinguished road
Re: Classmate ethernet port broken - fix?
That really stinks ! One thing you can do is to take apart the classmate and try to make tabs or bend new ones. Dont do this unless you are very confident in your ability to fix it!!!!!
Second, you can take it to a computer repair shop and i'm sure they can fix it for you. It's a pretty easy fix but you might need to get a new ethernet card in the process.
After you get it fixed use a small ethernet cable and a female-to-female plug to plug into, while leaving the short piece always connected into your computer. This will reduce wear and tear on the port and the new plug is easily replaceable.
Best of luck!
-Thomas
EDIT: I wouldn't buy a new classmate it seems to be an easy fix.
Alternatively, you could just jurryrig the plug with tape or zip ties such that its always in the port correctly,
then get a female to female plug for the other end.
-Team 1939 The Barstow Ku-Nig-Its!
Unread 02-02-2012, 12:52
I saw two teams with the same problem a couple of years ago. The "fix" was to use hot glue to hold a short Ethernet extension cable in place.
Unread 02-02-2012, 12:58
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
I'll second that...
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 02-02-2012, 15:55
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
we did the hot glue and then after the season tried to fix it, we did fix the enet port and in the process broke the keyboard. we ended up buying a new classmate but ours was 2 years old. be careful
http://www.team1912.com
2013, 2012, 2011, 2010 Regional Chairman's Award, Bayou Regional
2013 Woodie Flower's Award, Bayou Regional
2012 Dean's List Winner (Rachel Holladay)
2015, 2014, 2013, 2012, 2011, 2010 Beta Test Labview/Hardware
2012, 2011 Best Website, Bayou Regional
2011, 2009, 2006 Gracious Professionalism
2007 Bayou Regional Winner
Unread 04-02-2012, 19:01
Programming3335's Avatar
Programming3335 Programming3335 is offline
FRC #3335 (Cy-Borgs)
Programming3335 is an unknown quantity at this point
As some of the people above have suggested, our team has been using a small Ethernet cable with a female-to-female adapter on one end to remedy this problem. However, instead of hot-gluing it our team has tied it on with a rubber band. Been working fine since '09.
Unread 04-02-2012, 19:29
We wired a pigtail into ours in 2009 (is that hard wired?).
It made it secure and avoided having to open the case at the time.
We had to open it last year anyway to fix a broken power connector.
Unread 28-02-2012, 23:55
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
We broke ours too so we ordered the female to female off the FIRST choice and will be hot glueing it in place. Last year during the competition when I jerked a joystick too hard we came unplugged and couldn't finish the match...
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 28-02-2012, 23:58
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
I second/third/"x"th this solution.
Our original Classmate sports the "hot glue ethernet retaining fix."
In life, what you give, you keep. What you fail to give, you lose forever...
