Go to Post You can't expect a situation to get better if you don't make an attempt to confront it. - AndyB [more]
Unread 04-02-2012, 20:03
Re: Troubles on configuring a tank drive in LabView
You should never have to reimage the cRIO unless a new image is made available.
If you replace the Arcade Drive with Tank Drive, and supply it the appropriate joystick values, it should work. Can you show us the code you're trying to use?
